Hi all
I am using an EasyDriver (ROB-12779) to control a stepper motor, using AccelStepper library in Arduino.
Everything runs with no problem, I just have questions about EasyDriver’s RST (Reset) pin, it’s functionality and the concept of home position (or as I have found it the translator’s home state).
In EasyDriver’s datasheet says that RESET input sets the translator to a predefined home state:
The RESET input (active low) sets the translator to a predefined home state (see figures for home state conditions) and turns off all of the outputs. STEP inputs are ignored until the RESET input goes high.
is this home state a “hardware” predefined position (angle) of the motor’s shaft ?
OR it’s the first position at power on ? (when Arduino’s setup() runs)
does this “translator’s predefined home state” (or position I’ve found elsewhere) some predefined angle ? OR I am completely in a wrong path here ?
is this functionality (“hardware” predefined home position) available in maybe BigEasyDriver ?
if none of the above is true… are there any advice on how to achive this ?
I am really new in controlling motors so please be kind ![]()
regards
