I have purchased the following kit: https://www.sparkfun.com/products/16417
I have problems using the Edimax N150 . The connection is very bad. Sometimes the signal is very weak (no matter where I am) sometimes no signal can be received. Accordingly, I had to use the Ethernet KAbel until now. How can I solve this problem so that the Edimax N150 works properly?
