Enable SDRAM with AT91RM9200???
Hello Guys,
I´m trying to flash an SDRAM with 8MB “MT48LC4M16A2” with AT91RM9200. Here is my config file:
telnet_port 4444
gdb_port 3333
interface ft2232
ft2232_device_desc "Amontec JTAGkey A"
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
jtag_speed 2
reset_config trst_and_srst
jtag_device 4 0x1 0xf 0xe
jtag_nsrst_delay 250
jtag_ntrst_delay 250
daemon_startup reset
target arm920t little run_and_init 0 arm920t
run_and_halt_time 0 30
target_script 0 reset c:\Programas\amontec\sdk4arm\ocd\openocd\bin\temp.ocd
working_area 0 0x20000000 0x200000 nobackup
flash bank cfi 0x00000000 0x800000 4 1 0
and script to enable the SDRAM:
mww 0xffffff00 0x00000001   # cancel reset remapping
mww 0xfffffc20 0x0000ff01   # PMC_MOR: Enable main oscillator, OSCOUNT = 0xff
# Init flash
mww 0xffffff10 0x00000000   # MC_PUIA[0]
mww 0xffffff50 0x00000000   # MC_PUP
mww 0xffffff54 0x00000000   # MC_PUER: Memory controller protection unit disable
mww 0xffffff64 0x00000000   # EBI_CFGR
mww 0xffffff70 0x00003284   # SMC_CSR[0]: 16bit, 2 TDF, 4 WS
mww 0xffffff78 0x00003284   # SMC_CSR[2]: 16bit, 2 TDF, 4 WS
mww 0xffffff8c 0x00004182   # SMC_CSR[7]:  8bit, 1 TDF, 2 WS
# Init clocks
mww 0xfffffc28 0x2026be04   # PLLAR: 179.712000 MHz for PCK
sleep 10
mww 0xfffffc2c 0x10483e0e   # PLLBR: 48.054857 MHz (divider by 2 for USB)
sleep 10
mww 0xfffffc30 0x00000202   # MCKR : PCK/3 = MCK Master Clock = 59.904000MHz from PLLA
sleep 10
# Init SDRAM
mww 0xfffff870 0xffff0000   # PIOC_ASR: Configure PIOC as peripheral (D16/D31)
mww 0xfffff874 0x00000000   # PIOC_BSR:
mww 0xfffff804 0xffff0000   # PIOC_PDR:
mww 0xffffff60 0x00000002   # EBI_CSA : CS1=SDRAM
mww 0xffffff64 0x00000000   # EBI_CFGR:
mww 0xffffff98 0x21914155   # SDRC_CR :
mww 0xffffff90 0x00000002   # SDRC_MR : Precharge All
mww 0x20000000 0x00000000   # access SDRAM
mww 0xffffff90 0x00000004   # SDRC_MR : Refresh
mww 0xffffff90 0x00000003   # SDRC_MR : Load Mode Register
mww 0x20000080 0x00000000   # access SDRAM
mww 0xffffff94 0x000002e0   # SDRC_TR : Write refresh rate
mww 0xffffff90 0x00000000   # SDRC_MR : Normal Mode
when i:
flash probe 0
Info:    configuration.c:50 configuration_output_handler(): probing failed for flash bank '#0' at 0x00000000
Can anyone help me?
Thanks in advance,
Filipe Moutinho
Lectularius:
Hello Guys,
telnet_port 4444
gdb_port 3333
interface ft2232
ft2232_device_desc “Amontec JTAGkey A”
jtag_speed 2
Init flash
Init clocks
sleep 10
sleep 10
sleep 10
Init SDRAM
when i:
flash probe 0
Info: configuration.c:50 configuration_output_handler(): probing failed for flash bank ‘#0’ at 0x00000000
Can anyone help me?
Thanks in advance,
Filipe Moutinho
Greetings,
Schematic?
Best regards
Hello Davemaster,
Thanks for the reply.
The code for enable the SDRAM is fine, and i can load a binary file to the SDRAM with ‘load_binary’ command.
The command ‘flash_cfi’ it´s only for flash memories type…I think so…?
Now i have another problem. In debug, i can´t stop in the breakpoint :? . I will open another topic, with that doubt.
Regards,
Filipe Moutinho
