Error: cannot open device.
I am using ubuntu 8.0.4 and my cfg file is as follows
------start------------------
# port configurations
telnet_port 4444
gdb_port 3333
# cpu configuration
source [find target/lpc2148.cfg]
# interface configuration
source [find interface/parport.cfg]
--------end-----------------
$ openocd -f test.cfg
I get the following error
Open On-Chip Debugger 0.4.0 (2010-05-18-16:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
RCLK - adaptive
jtag_nsrst_delay: 200
jtag_ntrst_delay: 200
trst_and_srst srst_pulls_trst srst_gates_jtag trst_push_pull srst_open_drain
parport port = 0x378
Error: cannot open device. check it exists and that user read and write rights are set. errno=2
Command handler execution failed
I checked in /dev directory and /dev/parport0 exists
and i even changed the permissions
by using
$ sudo chmod 777 /dev/parport0
and i disabled lp by adding the following line
blacklist lp to
/etc/modprobe.d/blacklist
and i still get this stupid error.
Module Size Used by
rfcomm 41744 2
l2cap 25728 13 rfcomm
bluetooth 61028 4 rfcomm,l2cap
ppdev 10372 0
vmnet 50112 16
vmblock 16672 1
vsock 46368 0
vmci 59608 1 vsock
vmmon 79020 0
acpi_cpufreq 10796 1
cpufreq_stats 7104 0
cpufreq_userspace 5284 0
cpufreq_conservative 8712 0
cpufreq_ondemand 9740 1
freq_table 5536 3 acpi_cpufreq,cpufreq_stats,cpufreq_ondemand
cpufreq_powersave 2688 0
ac 6916 0
container 5632 0
video 19856 0
output 4736 1 video
sbs 15112 0
sbshc 7680 1 sbs
dock 11280 0
battery 14212 0
iptable_filter 3840 0
ip_tables 14820 1 iptable_filter
x_tables 16132 1 ip_tables
sbp2 24072 0
lp 12324 0
ipv6 268036 24
snd_usb_audio 83936 0
snd_hda_intel 346264 1
snd_pcm_oss 42144 0
snd_mixer_oss 17920 1 snd_pcm_oss
uvcvideo 58244 0
snd_pcm 78724 3 snd_usb_audio,snd_hda_intel,snd_pcm_oss
snd_seq_dummy 4868 0
compat_ioctl32 2304 1 uvcvideo
snd_seq_oss 35584 0
snd_page_alloc 11400 2 snd_hda_intel,snd_pcm
videodev 29440 1 uvcvideo
snd_usb_lib 18560 1 snd_usb_audio
v4l1_compat 15492 2 uvcvideo,videodev
snd_seq_midi 9376 0
snd_seq_midi_event 8320 2 snd_seq_oss,snd_seq_midi
nvidia 7825536 34
v4l2_common 18304 2 uvcvideo,videodev
snd_rawmidi 25760 2 snd_usb_lib,snd_seq_midi
snd_seq 54224 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_hwdep 10500 2 snd_usb_audio,snd_hda_intel
i2c_core 24832 1 nvidia
sky2 47620 0
snd_timer 24836 2 snd_pcm,snd_seq
snd_seq_device 9612 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 56996 15 snd_usb_audio,snd_hda_intel,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_dummy,snd_seq_oss,snd_usb_lib,snd_rawmidi,snd_seq,snd_hwdep,snd_timer,snd_seq_device
evdev 13056 3
intel_agp 25492 0
pcspkr 4224 0
button 9232 0
parport_pc 36260 1
parport 37832 3 ppdev,lp,parport_pc
iTCO_wdt 13092 0
iTCO_vendor_support 4868 1 iTCO_wdt
shpchp 34452 0
pci_hotplug 30880 1 shpchp
agpgart 34760 2 nvidia,intel_agp
soundcore 8800 1 snd
ext3 136968 1
jbd 48404 1 ext3
mbcache 9600 1 ext3
loop 18948 2
usbhid 32128 0
hid 38784 1 usbhid
sg 36880 0
sr_mod 17956 0
cdrom 37408 1 sr_mod
sd_mod 30720 3
8139cp 24704 0
ata_piix 19588 2
pata_jmicron 7040 1
pata_acpi 8320 0
ohci1394 33584 0
ieee1394 93752 2 sbp2,ohci1394
8139too 27648 0
mii 6400 2 8139cp,8139too
ata_generic 8324 0
libata 159728 4 ata_piix,pata_jmicron,pata_acpi,ata_generic
scsi_mod 151692 5 sbp2,sg,sr_mod,sd_mod,libata
ehci_hcd 37900 0
uhci_hcd 27024 0
usbcore 146412 7 snd_usb_audio,uvcvideo,snd_usb_lib,usbhid,ehci_hcd,uhci_hcd
thermal 16796 0
processor 36616 2 acpi_cpufreq,thermal
fan 5636 0
fbcon 42912 0
tileblit 3584 1 fbcon
font 9472 1 fbcon
bitblit 6784 1 fbcon
softcursor 3072 1 bitblit
fuse 50708 5
I have encounter the things, don’t open device parport0. I don’t known whether you have solved it. Can you tell me if you have solved it.
If you look at the parport.cfg you will see that by default it tries to open address 0x378 - this is the default normally in windows.
Newer versions of the script have a PARPORTADDR var that can be overridden to suit your local setup.
set PARPORTADDR /dev/parport0
Cheers
Spen
