before we did boundary scan register checking every thing worked fine,now its showing no device found error.we connection like usb cable target every thing working fine.we are not able to able to solve this issue please help me.
root@yash06-To-be-filled-by-O-E-M:/home/yash06/Documents/openocd-bin# openocd -f interface/ftdi/ngxtech.cfg -f target/sama5d36.cfg
Open On-Chip Debugger 0.10.0+dev-00563-gda4b2d5-dirty (2018-10-30-15:26)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
WARNING!
This file was not tested with real interface, but is assumed to work as this
interface uses the same layout as configs that were verified. Please report your
experience with this file to openocd-devel mailing list, so it could be marked
as working or fixed.
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter speed: 1500 kHz
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select ’.
eMMC{
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘NGX JTAG’, serial ‘’ at bus location '’
