My research group has ordered two sets of u.fl antennae to attach to a set of LoRa single channel gateways that we have ordered. Upon testing the range of the antennae along with a simple copper wire antenna, we found that the range of the copper wire far exceeds the range of the antennae that we ordered. Abnormally so.
Copper Wire Range ~ 1 mile
Anaren whip antennae (3dBi gain) ~ 50 feet
(https://www.digikey.com/en/products/det … MHPDqxq0gA)
Linx Tech 916MHZ WHIP/TILT CONN ~ 50 feet
(https://www.digikey.com/en/products/det … sMIALoBfIA)
It doesn’t make sense that these antennae would get such sort range, when a simple copper wire gets us a range as far as a mile. If anyone has experience with this type of issue or suggestions, please reach out.
