I am pretty new to this board and I faced a problem where I was not able to power on my board, at least, the LED on the board would not turn on when I connect it to a power source via a USB-C cable. I installed the necessary drivers but even in the Arduino IDE, I cannot access the Ports and select them, even when it should be connected. I am not sure if there is something I am forgetting and I can hardly find any information online. Thank you!
Which main board are you using? The usb on the function board is only to update firmware if you have an issue that updating would fix
I understand. That makes a lot more sense, as I was trying to use it with a main board. Thank you and sorry for my misunderstanding!
