ESP32 Thing Plus not running a Blink example with a battery
The ESP32 will work while plugged into the USB port, but will not work with just the battery connected. Any suggestions?
Double-check the battery’s voltage and polarity versus the board’s connector
Both + and - pins were not soldered to the ESP32 board. Easy fix!
