Using the RESET button causes a normal boot up. The regular ESP32 Thing boots normally when power is applied - I was expecting the WROOM to do the same thing - is it defective?
It’s a simple setup - just a WROOM connected to a SparkFun serLCD using a QWIIC cable.
Any ideas how to fix this boot problem? Should I just return the WROOM as defective?
False alarm - it does boot on power-up but the serLCD needed a 1 sec delay added otherwise my initial display text wasn’t showing up.
Wire.begin();
lcd.begin(Wire); //Set up the LCD for I2C communication
lcd.setBacklight(200, 170, 255); //Set backlight color mix
lcd.setContrast(5); //Set contrast. Lower to 0 for higher contrast.
delay(1000);
