Hi group,
I have had an ET301 for a bit and finally I am trying to work with it. I have discovered that it doesn’t have a lot of support detail such as what its default baud rate / comm settings are, or what messages it sends by default. I have been trying to catch its startup output via a logic analyzer, but no luck. Is there any docs on its default settings for startup? Or if someone does know the defaults, could you post them?
DB
