Facet Rover in Missouri with MoDOT real time network
Engineer here, but complete novice regarding GNSS and RTK equipment. The Missouri DOT operates a free RTK network across my state. Their FAQ’s talk about needing dual frequency receivers etc., and I just don’t understand this stuff. I would like to get a single facet rover and use it with this MoDOT network for cm level accuracy. Is that possible?
Jeff
You’d likely just need to feed the MoDOT correction data into NTRIP - it can be confusing, just take your time and read through things a few times
General correction settings for facet https://docs.sparkfun.com/SparkFun_RTK_ … n_sources/
Using MoDOT with NTRIP, this thread notes some pitfalls/caveats that you might find helpful in trying to get yours configured https://github.com/tomojitakasu/RTKLIB/issues/584
MoDOT info https://gpsweb3.modot.mo.gov/faq.html
