I’m just learning about RTK…
We’d like to be able to go out in the field, setup 1 Facet unit as a base, and 1 Facet unit as a rover. I’m guessing the base unit will need internet connectivity for the NTRIP server. I suppose a cell phone can run a wifi hotspot and the base can connect to it for connectivity. Then, it appears we would need another mobile phone connected to the rover for it’s connectivity.
Is there a way for the rover to get the correction data directly from the base over wifi? I understand the range would be limited to the espressif wifi connection range.
Correct me if I’m thinking wrong. Also, any other options to do this?
