I am trying to upload via the Arduino IDE running on Linux (Ubuntu) using the Ambiq bootloader set to the default 921600 baud rate.
Before hitting the upload button, I have followed the suggestions mentioned here to load the board into boot mode correctly. i.e: Hold reset, Hold 14, Remove Reset, Keep holding 14 throughout the upload.
When uploading the micro speech example, towards the end of the upload: The blue LED starts flashing while I am pressing button 14 and then the “failed to upload error” is shown on the Arduino temrinal.
To remove the hassle of working with the Ambiq bootloader, I tried to install SVL. I ran the “burn bootloader” option while holding button 14 but the “failed to upload” error still popped up.
I have tried changing baud rate to the conference one, but that didn’t fix the issue. Any way to fix this?
