I need help to find where I can buy female pin headers for the PICASO MD 1 module. I have tried to find a place where you can buy those small pin headers, but it seems impossible.
Regards,
Simon
Regards,
Simon
impossible until you look in the right place.
Mill Max has lots of sockets that will fit headers. Figure out the header pin size on the module and then look up the right socket size. Mouser carries mill max as do many other distis.
Well, I measured the spacing between the pins and it was 1.25 - 1.27 mm.
They had a lot of headers on te sites you gave me, but not a female header in that size.
No offense, but I don’t think you are looking very hard. In about 3 minutes of poking around mouser I found a bunch mill max of 1.25 mm sockets. 1.27 is .05" so you can also look for that.
Thanks for the tip. Now I founded the right header for my graphic controller.
I did look for a long time, but it was my fault, because I don’t know so much about these kinds of items, so I was looking for the wrong item.
Thanks a lot ![]()
Simon
