Does anyone know what would happen if you powered the FEMTObuck LED driver without anything attached to the output (LED) side? Will it damage the driver?
It’ll behave like any other incomplete circuit…there would be voltage at the LED pins, which could short on other things…but broadly speaking the answer is “No, that should not damage the board”
Are you having issues?
