So, I just purchased my zed-f9p-02b and started the “Setting up a rover base rtk system” tutorial. Everything was working fine as far as the messages windows and I had a lot of satellites showing. One of the first things in the tutorial was to check my firmware and update if not the latest. I did so and now I get no messages and none of the GUI windows show any satellites. I updated to the 1.21 version from the 1.3. The program shows I’m connected via the COM port. In the Messages UBX MON VER window it shows that it updated and the COM port icon shows it as connected. On the board itself, I have a blue LED and a red LED lit. The yellow LED that was flashing before is no longer flashing ( I assume that was the Serial USB connection). Any ideas? Can I back up to the previous firmware? I should have stuck with the axiom “The enemy of good is better”
Try also updating to the latest version of U-center here https://www.u-blox.com/sites/default/fi … 54.exe.zip and see if that’s the hiccup…if not, we can go further
I don’t understand, if updating firmware is so problematic; why on earth does your tutorials basically insist on us updating the firmware??? seems very irresponsible and cost me a LOT of time this morning. Thankfully it didn’t brick the units, but still; do better guys!
Where in the guide does it say to upgrade firmware?
