u-center Documentation-installed Program Discrepancy
Hello Sparkfun Community,
I’m using u-center 2 to upgrade the firmware of ZED-F9R module. I’m using the documentation from https://learn.sparkfun.com/tutorials/ho … troduction. I download u-center from https://www.u-blox.com/en/product/u-center. However, the interface from this software does not match the documentation at all. The documentation tells me to use the “tools” tab to upgrade the firmware. However, in u-center 2, there is no tab remotely close to “tools.” I’m using the firmware from https://www.u-blox.com/en/product/zed-f … -resources named ZED-F9R HPS1.21 firmware. What should I do to get the software the documentation is referring to? How can I upgrade the firmware of my breakout board?
Best Regards.
Is your question not covered by the “firmware update” section in the official u-center documentation from U-blox?
https://www.u-blox.com/sites/default/fi … 005250.pdf
Just read the documentation. The documentation uses u-center. However, there is only the u-center 2 available for download. Most of your documentations are towards u center. Is there a link where I can download u center 1 instead of u center 2?
Have a look at the “Documentation & resources” tab at https://www.u-blox.com/en/product/u-center . The links to the original u-center are still there:
https://www.u-blox.com/sites/default/fi … 02.exe.zip
