I can't update zed f9p from 1.13 to 1.30
Hello, I am having trouble updating the zed f9p from Sparkfun facet v2.3.
The current firmware is 1.13 and I want to put version 1.30
It gives me errors with both the Sparkfun application and the u-block application.
I upload images.
If something occurs to you, I thank you.
I upload images
I already solved with instructions obtained from a u-block page.
"I also had this problem when trying to update to the new 1.32 firmware. I copied ftd2xx.dll from my Arduino folder C:\Program Files (x86)\Arduino\drivers\FTDI USB Drivers\i386
into ublox folder C:\Program Files (x86)\u-blox\u-center_v22.02. Worked great!"
Thank you so much for reporting the solution you found.
