I access the forum from home and from work. Usually, I have to re-login and whatever cookies or website-resident data that keeps track of my prior visits is reset to nada…
I’ve tried deleting the cookie folder for sparkfun (or at least what I think it is), on both PCs.
Is this an issue with my PCs or with the forum user account?
I also access the forum from work and home, but I’ve never had a problem with having to re-login. It also always correctly remembers the “posts since your last visit”.
I’m using IE7 with default security settings; not sure about you…
I’m also assuming you use the forum check-box to “remember my login”, rather than the IE / Firefox option to remember password.
This is called the session expire issue. Please check the default setting of the browser. And use the Roboform software for automatic login. Don’t forget to select the remember option when you log in.
