FLIR Lepton field of view
Folks,
I need to track the position of a person/group of people at night for a Halloween prop. What’s the size of the field of view of this camera (3’ of so from the lens), do you think that this is a suitable application and/or do you have any other suggestions?
You’d need a bit of geometry to calculate this, but the field of view out of the lens for these is 50°.
Hope this helps!
thank you, is it 50 vertical too?
and what is the focal distance? might one “fly” this on a drone?
thanks again. C
Here’s a link to the data sheet for the camera we carry:
https://www.flir.com/globalassets/impor … asheet.pdf
If that doesn’t answer your questions, [FLiR might be able to help since they are the ones that manufacture this part.
I don’t see any reason why you couldn’t put one of these on a drone though since they are small and light weight but you’d need to try it to verify it works OK.](https://www.flir.com/)
The field of view is approximately 50 degrees.
Build from this.
