forum rejects posts because of "forbidden words"
how can i post debug logs to the openocd board? My posts get rejected because of “usage of forbidden words”, and i am told to subscribe to the ‘bypass words’ group. This group doesnt seem to exist?
cheers,
…oops! my realname is also on the forbidden-word list…
  • dc
Hey,
The issue is our new spam blocker - I’m gonna add that group now.
I also will approve your posts - so don’t worry about reposting.
Cheers,
–David Carne
I just had the same issue. I joined the only group I could and then tried to post again, but no luck.
Help appreciated!!
approved your membership. You’re good to go.
Cheers,
–David Carne
I’m getting trapped by the forbidden words ban too. Can a moderator approve my membership and also my post? I was trying to start a new thread. Every word is highly technical; I can’t imagine what a spam blocker would object to.
I’m in the same situation, can my account be added to the bypass group too ?
I posted a new thread, should I repost it or is going to be validated by a moderator ?
Same issue here, seems posting here gets your account accepted. Any chance there is a list of the forbidden words? In a past post, I found .txt was forbidden, the rest of the post was fine.
Click on the Usergroups link at the top of the page and join the Bypass Spam Filter group. Once the moderator adds you to the group you should be fine.
I am also suffering fromt his problem
My first post vanished into the ether, the second simplified one seems to be going the same way. Is there any way to learn what words are forbidden? I have applied for the “bypass words” group, hope that helps but I also hoped to write a clean enough entry to make it in :slight_smile:
