http://www.freechargecontroller.org/ima … _4_04b.pdf
I’m hoping to get an explanation of the 12.2K Ohm resistor assemblies on both power terminals. Why are these part of the design?
Thank you.
Thank you.
Do you mean the 2.2k and 10k resistors ? It appears they are making a voltage divider to reduce the voltage sent to an external monitor. The cap adds a low pass filter.
