I stumbled across this today. Looks like a great solution for hobbyists and looks like it exports to gerber files.
Give it a look and post your impressions.
:shock:
Whoa. 7 minutes after downloading the program, I’ve dropped two ICs down, connected some pins, added some silkscreen text, added a ground plane, ran a DRC, and exported gerber files that I could then import correctly into our CAM software.
:shock:
I’ve got to email a few hundred students and teachers. Be right back.
-Nathan
So I get a star for the day? :lol:
As a follow up. If you want to create schematics and netlists to import into FreePCB use TinyCAD. (Free again)
http://tinycad.sourceforge.net/
Finally if you plan on creating you own PCB with the software you will need Viewmate to print. (the software doesn’t print yet) Additionally Viewmate can be used to view your files prior to submitting them to Sparkfun (of coarse free) ![]()
I emailed the author. He’s a FIRST Robotics guru and liked our site
I will link to the software from the PCB Deal page.
Good finds! Possibly a star with a ‘Good job’ written next to it? It’s silly to think what I valued back in the forth grade…
-Nathan
Nathan,
You mentioned using FreePCB and importing the results with your software. I tried a simple board with FreePCB and the drill file appears to be 2.4 format instead of the 2.3 format which you request (see below). Does that mean you can accept 2.4? I don’t find an option in FreePCB for 2.3 but could certainly convert the resultant file to 2.3 if necessary. I have had several other successful submissions with a different software package but I need to switch since the other package is no longer supported.
Can we submit 2.4 under the ‘successful submission’ price or should I convert to 2.3?
Bob
;Holesize 1 = 35.0 PLATED MILS
M48
INCH
T01C0.035
G05
G90
T01
X005500Y012000
X006500Y012000
X007500Y012000
X008500Y012000
X009500Y012000
X010500Y012000
X011500Y012000
X012500Y012000
X013500Y012000
X014500Y012000
X015500Y012000
X016500Y012000
X017500Y012000
X018500Y012000
X019500Y012000
X020500Y012000
X021500Y012000
X022500Y012000
M30
Hey Bob,
There are a few other posts about this but I will reiterate: We can accept anything but it’s Ben who has to guess at what format you’ve got. We give up after about 3 tries. Please make your drill file 2.3 - it very easy on us. If it’s something else, please include a file that says ‘6.3 drill format.txt’ or something so that Ben can import your gerbers.
Everything coming out of Protel is 2.3. Everything coming out of Eagle is 2.4.
-Nathan
That's not entirely accurate. The latest EAGLE version (4.14) defaults to 2.4 format but you can change it back to 2.3 format by editing the eagle.def file in the bin directory.sparky:
See [this thread for more information.
Don](http://www.sparkfun.com/cgi-bin/phpbb/viewtopic.php?t=1235)
