When I generate the CAM files from freepcb, the files end with a .grb extension. When I upload those files, BatchPCB tells me that they only accept the file formats:
TopCopper - “.gtl” , “.cmp”, “.top”
BottomCopper - “.gbl”, “.sol”, “.bot”
TopSolderMask - “.gts”, “.stc”, “.smt”, “.stoptop”, “.tsm”
BottomSolderMask - “.gbs”, “.sts”, “.smb”, “.stopbot”, “.bsm”
TopSilk - “.gto”, “.plc”, “.sst”, “.positop”, “.leg”, “.slk”
BottomSilk - “.gbo”, “.pls”, “.ssb”, “.posibot”, “.bsk”
Drill - “.drl”, “.txt”, “.tap”, “.drill”, “.gdd”, “.drd”, “.cnc”, “.exl”
KeepOut - “.gko”
MiddleCopper1 - “.g2”
MiddleCopper2 - “.g3”
BottomStencil - “.gbp”
TopStencil - “.gtp”
Outline - “.outline”, “.oln”
Is there a way for freepcb to generate those or for me to convert the .grb to the accepted formats?
Thanks in advance!
