FreeRTOS on MSP430 using CCE
I’d like to get FreeRTOS running on an MSP430 processor using Code Composer Essentials v3.1. I found an example of just this at http://www.westmorelandengineering.com/toc.htm. Specifically I’m working with http://www.westmorelandengineering.com/ … S_Demo.zip. When I try to open it with CCE I get an error that the workspace “was not created by this version of Code Composer”. So I tried to import the project and I get an error “The Managed Make project could not be read because of the following error: Project type com.ti.ccstudio.managedbuild.ui.programTargetID not found. Managed Make functionality will not be available for this project.”
I’m wondering what my problem is and how I can get the project to build, or should I go about this a different way?
