Garage Door Rolling Code
Has anybody worked with building their own rolling code garage door remote? My Googling isn’t coming up with anything about how this would be implemented.
I roamed the 'net some time ago and found the basic algorithm - maybe this is what I read
http://en.wikipedia.org/wiki/Rolling_code
As I recall, it’s a conventional pseudo-random number generator. So the sequence is well known if you know the seed. I think the tricky part is that the receiver (door controller) has to remember what each remote trained-on, in the sequence. And there’s a window in the sequence, where any of the next n (hundred) codes are acceptable - permitting the transmitter to skip some codes.
But, I’m semi-speculating.
I also don’t know how brand A transmitter can sych to brand B receiver, unless they have some way to be given the common seed.
So in short, I don’t know for sure.
