gcc compiler version
I’m using arm-elf-gcc version 3.4.5 on a Linux machine. What version are other people using? Thanks.
I’m using a prebuilt arm-elf-gcc 4.1.0 on Windows with cygwin. On the same machine, I’m also running Linux (Ubuntu 6.10) and running arm-elf-gcc 3.4 there (=latest binary version I could find at gnuarm.net).
Have you guys had any luck building the full gnuarm.net toolchain on Linux? I seem to get it all the way done but in the end, when I use the tools, I get complaints about floating point (even though, following the gnuarm.net instructions, I compiled with soft-float support). That said, I’m using a pre-built 4.1.0+newlib toolchain for now.
I am using gcc 4.1.1 on Fedora Core 6.
