SteM
November 7, 2006, 5:27pm
1
Hello everybody,
i’m compiling a source code with 3 different arm-elf-gcc.exe compiler and i’m receiving a strange error:
D:\DOCUME~1\qqqq\IMPOST~1\Temp/ccMraaaa.s: Assembler messages:
D:\DOCUME~1\qqqq\IMPOST~1\Temp/ccMraaaa.s:650: Error: can’t resolve main' {.text section} - main’ {.text section}
make: *** [src/main.o] Error 1
ver.4.1.0, cygwin needed, from GNUArm, no error
ver.4.1.1, cygwin needed, from GNUArm, error !
ver.4.1.1, cygwin NO needed, from Yagarto, error !
Is there any problem in version 4.1.1 ?
Could you please try with our sdk4arm GAT module including ver 4.1.0 CYGWIN NO needed from
http://www2.amontec.com/sdk4arm/win32/a … 29-rc1.exe
Here is the content of the amontec-sdk4arm-gat-20060729-rc1.exe :
http://www2.amontec.com/sdk4arm/win32/a … 29-rc1.pdf
We already saw some difficulties with the 4.1.1. For us, the ver4.1.0 is more stable. This is why we are waiting for updating to 4.1.x.
Regards,
Laurent
SteM
November 10, 2006, 5:49pm
3
Solved !!
I solved my problems: i took other project and that was compilable without problems.
So i compare Makefiles: i discovered a little number of differences but the most important one is the -g option that, in the good project was equal to ‘dwarf-2’, on the bad project ‘stabs’.
I think there should be some differences for 4.1.1 version of arm-elf-gcc …
Now i can compile with both 4.1.0 and 4.1.1
Thanks !
