gdb can't find sources
this is not not a OpenOCD problem someone around here can help.
I’ m using OpenOCD r520 with Yagarto GDB 6.8.50.
I’m not able to set breakpoints because gdb says:
No source file named D:/Projekte/proj/src/source.c.
Some testing showed that cygdrive/d/… works.
Seems like this arm-elf-gdb was compiled for cygwin?
Typing ‘list source.c:0’ as user command works too.
Unfortunately my Editor (CodeBlocks) uses full paths to talk to gdb.
We arranged source files over several directories.
/proj/tests/mytest
/proj/src/
Where my project lies under /mytest and the common sources
lies under /src.
Copying every source I want to debug directly under /mytest
everything works.
What would be the best solution?
Regards Joerg
Using a non cygwin version of arm toolchain maybe:
http://www.yagarto.de/#download
