There is a lot of information about cfg files now which is great.
I cannot find any information on this Forum or the Belinos site about what GDB commands are needed for a particular target in a particular mode.
I am doing Flash Debugging on the LPC2103 at the moment.
I use
target remote localhost:3333
monitor soft_reset_halt
monitor arm7_9 force_hw_bkpts enable
symbol-file main.elf
thbreak main
continue
which gives me the warning
Warning: arm7_9_common.c:679 arm7_9_assert_reset(): srst resets test logic, too
I got this from searching on the web and Jim Lynch’s tutorials.
Do we not need to add a page for this on the Wiki ?
My commands are working but should I be using others ?
I am using the Yagarto tool chain with a Signalzer at the moment.
You will see I am not programming the flash by JTAG at this time. I use the Philips Utility via the serial port at the moment.
Thank you Dominic and others for a great tool.
