I have followed the Yagarto install procedure but I get the following error while starting the debugger in flash mode: “Error finishing flash operation”. The debugger starts and I am able to step through the example code (provided by Yagarto), however the target reset when I it the addition line (for those who are not familiar with the example, the code features a forever loop with an addition).
I use a custom made LPC2129-based board, which I can perfectly program using the flashmagic. I use the modified files from the LPC21248 example available on the yagarto site. I did modify the jtagkey.cfg because I am using an ARM-USB-OCD jtag interface from Olimex and the flash size of the lpc2129 is only #256k. Here is the cfg.
For more information about the configuration files, take a
look at the “Open On-Chip Debugger (openocd)” documentation.
This config file was tested with OpenOCD version r717
daemon configuration
telnet_port 4444
gdb_port 3333
tell gdb our flash memory map
and enable flash programming
gdb_memory_map enable
gdb_flash_program enable
interface, if you want to use an other interface
you must replace this section here
#################### interface start ####################
interface ft2232
ft2232_device_desc “Olimex OpenOCD JTAG A”
ft2232_layout “olimex-jtag”
ft2232_vid_pid 0x15BA 0x0003
##################### interface end #####################
start slow, speed up after reset
jtag_khz 20 1500
#delays on reset lines
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#LPCs need reset pulled while RTCK is low. 0 to activate JTAG, power-on reset is not enough
jtag_reset 1 1
jtag_reset 0 0
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_init 0 arm7tdmi-s_r4
run_and_halt_time 0 30
target_script 0 reset ./prj/lpc2148_reset_oocd.script
working_area 0 0x40000000 0x4000 nobackup
#flash bank lpc2000 0 0 <target#>
flash bank lpc2000 0x0 0x40000 0 0 0 lpc2000_v2 14765
Here is the console output on eclipse:
target remote localhost:3333
0x0000028c in ?? ()
monitor reset
JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
executing reset script ‘./prj/lpc2148_reset_oocd.script’
monitor sleep 500
monitor poll
target state: halted
target halted in ARM state due to debug request, current mode: Supervisor
cpsr: 0x600000d3 pc: 0x0000028c
monitor soft_reset_halt
requesting target halt and executing a soft reset
monitor arm7_9 force_hw_bkpts enable
force hardware breakpoints enabled
monitor mww 0xE01FC040 0x0001
monitor mdw 0xE01FC040
0xe01fc040: 00000001
set mem inaccessible-by-default off
load
Loading section .text, size 0x16c lma 0x0
break main
Breakpoint 1 at 0x10c: file src/main.c, line 71.
continue
Note: automatically using hardware breakpoints for read-only addresses.
Breakpoint 1, main () at src/main.c:71
71 DWORD a = 1;
Here is the output of the openocd window:
C:\Documents and Settings\Administrator\workspace\lpc2148Test>openocd-ftd2xx -f prj\jtagkey.cfg
Open On-Chip Debugger (2008-06-19 19:00) svn: 717 URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Info: options.c:50 configuration_output_handler(): jtag_khz: 10, 10
Info: options.c:50 configuration_output_handler(): Open On-Chip Debugger (2008-06-19 19:00) svn: 717
Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Info: target.c:237 target_init_handler(): executing reset script ‘./prj/lpc2148_reset_oocd.script’
Info: server.c:78 add_connection(): accepting ‘gdb’ connection from 0
Warning: gdb_server.c:416 gdb_get_packet_inner(): acknowledgment received, but no packet pending
User: target.c:957 target_arch_state(): target state: halted
User: armv4_5.c:307 armv4_5_arch_state(): target halted in ARM state due to debug request, current mode: Supervisor
User: target.c:1838 handle_soft_reset_halt_command(): requesting target halt and executing a soft reset
User: gdb_server.c:574 gdb_output(): force hardware breakpoints enabled
User: gdb_server.c:574 gdb_output(): 0xe01fc040: 00000001
Warning: lpc2000.c:611 lpc2000_write(): lpc2000 returned 6
Error: flash.c:103 flash_driver_write(): error writing to flash at address 0x00000000 at offset 0x00000000 (-902)
Warning: arm7_9_common.c:1950 arm7_9_read_memory(): memory read caused data abort (address: 0xffffffff, size: 0x1, count: 0x1)
Here are the openocd initialization commands:
monitor reset
monitor sleep 500
monitor poll
needed for gdb 6.8 and higher
load
break main
continue
Finally, here is the memory map for the lpc2129 (taken from lpc2148 and modified):
Copyright (c) 2006 by Michael Fischer. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
- Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
- Neither the name of the author nor the names of its contributors may
be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
“AS IS” AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL
THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF
THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
SUCH DAMAGE.
History:
26.01.08 mifi First Version
ENTRY(ResetHandler)
SEARCH_DIR(.)
- Define stack size here
FIQ_STACK_SIZE = 0x0100;
IRQ_STACK_SIZE = 0x0100;
ABT_STACK_SIZE = 0x0100;
UND_STACK_SIZE = 0x0100;
SVC_STACK_SIZE = 0x0400;
This file, olimex_lpcp2148_ram.ld, locate the program in the internal
ram of the LPC2148. For more information about the memory of the LPC2148
take a look in the LPC2141/2142/2144/2146/2148 USER MANUAL.
Reference is made to the user manual from 25 July 2006 Rev. 02
Take a look at page 8, section 1.Memory maps
MEMORY
rom : org = 0x00000000, len = 256k
ram : org = 0x40000000, len = 16k
- Do not change the next code
SECTIONS
.text :
*(.vectors);
. = ALIGN(4);
*(.init);
. = ALIGN(4);
*(.text);
. = ALIGN(4);
*(.rodata);
. = ALIGN(4);
(.rodata);
. = ALIGN(4);
*(.glue_7t);
. = ALIGN(4);
*(.glue_7);
. = ALIGN(4);
etext = .;
} > rom
.data :
PROVIDE (__data_start = .);
*(.data)
. = ALIGN(4);
edata = .;
_edata = .;
PROVIDE (__data_end = .);
} > ram
.bss :
PROVIDE (__bss_start = .);
*(.bss)
*(COMMON)
. = ALIGN(4);
PROVIDE (__bss_end = .);
. = ALIGN(256);
PROVIDE (__stack_start = .);
PROVIDE (__stack_fiq_start = .);
. += FIQ_STACK_SIZE;
. = ALIGN(4);
PROVIDE (__stack_fiq_end = .);
PROVIDE (__stack_irq_start = .);
. += IRQ_STACK_SIZE;
. = ALIGN(4);
PROVIDE (__stack_irq_end = .);
PROVIDE (__stack_abt_start = .);
. += ABT_STACK_SIZE;
. = ALIGN(4);
PROVIDE (__stack_abt_end = .);
PROVIDE (__stack_und_start = .);
. += UND_STACK_SIZE;
. = ALIGN(4);
PROVIDE (__stack_und_end = .);
PROVIDE (__stack_svc_start = .);
. += SVC_STACK_SIZE;
. = ALIGN(4);
PROVIDE (__stack_svc_end = .);
PROVIDE (__stack_end = .);
PROVIDE (__heap_start = .);
} > ram
/*** EOF ***/
Any idea on how to fix this issue?
Jean-Sebastien
