Hey All,
I thought I might find an existing topic about this but haven’t been able to! After in the past few days succesfully following the Yagarto (http://www.yagarto.de/) howto and getting everything installed, I now want to be able to load/debug my programs in flash ![]()
I’m using the LPC-P2148 dev board and ARM-USB-OCD .
Another post pointed me in the direction of: http://www.siwawi.arubi.uni-kl.de/avr_p … index.html
which admittedly seemed very helpful. But after reading, downloading, and tweaking the files, I’ve been unable to get it going!
The example program seems to build fine, but when I attempt to run openocd_go_flash.cmd I get the msg:
Error: lpc2000.c:384 lpc2000_flash_bank_command(): unknown LPC2000 variant
Error: flash.c:180 handle_flash_bank_command(): ‘lpc2000’ driver rejected flash bank at 0x00000000
had a poke around but couldn’t work out what was causing this one. If anyone can see the cause of that problem, or any other ones in my config that’d be awesome.
@echo off
call openocd_install_info.cmd
if %OOCD_INTERFACE% == PP goto LAB_PP
if %OOCD_INTERFACE% == FTDI goto LAB_FTDI
echo ERROR - set interface in openocd_install_info
goto LAB_END
:LAB_FTDI
set OOCD_EXE=%OOCD_BIN_FTDI%
set OOCD_CFG=openocd_lpc2148_flash_ftdi.cfg
goto LAB_DOIT
:LAB_PP
set OOCD_EXE=%OOCD_BIN_PP%
set OOCD_CFG=openocd_lpc2148_flash_wiggler.cfg
:LAB_DOIT
rem set OOCD_DBG=-d 1
%OOCD_EXE% %OOCD_DBG% -f %OOCD_CFG% -d3 -lopenocd.log
:LAB_END
rem pause
rem -
set OOCD_INSTALLDIR=C:\openocd-2007re204\bin
set OOCD_BIN_FTDI=%OOCD_INSTALLDIR%\openocd-ftd2xx.exe
set OOCD_BIN_PP=%OOCD_INSTALLDIR%\openocd-pp.exe
rem The used interface either FTDI(=WinARM-JTAG, JTAGKEY etc.) or PP(="Wiggler")
set OOCD_INTERFACE=FTDI
rem set OOCD_INTERFACE=PP
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Olimex OpenOCD JTAG A"
ft2232_layout "olimex-jtag"
ft2232_vid_pid 0x15BA 0x0003
jtag_speed 3
#interface
#interface ft2232
#ft2232_device_desc "Amontec JTAGkey A"
#ft2232_layout jtagkey
#ft2232_vid_pid 0x0403 0xcff8
#jtag_speed 3
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can't set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
run_and_halt_time 0 30
# flash-options LPC2148
target_script 0 reset openocd_lpc2148_flash.script
working_area 0 0x40000000 0x4000 nobackup
# LPC2138 @ 12MHz / 0x7D000 from 500*1024 (not 512!)
flash bank lpc2000 0x0 0x7D000 0 0 lpc2000_v2 0 12000 calc_checksum
arm7_9 dcc_downloads enable
wait_halt
sleep 10
poll
flash probe 0
flash erase 0 0 0
flash write_binary 0 main.bin 0x0
reset run
sleep 10
shutdown
openocd.log
Error: flash.c:180 handle_flash_bank_command(): 'lpc2000' driver rejected flash bank at 0x00000000
Debug: jtag.c:1407 jtag_init(): -
Debug: ft2232.c:1296 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'olimex-jtag' layout (15ba:0003)
Debug: ft2232.c:1385 ft2232_init_ftd2xx(): current latency timer: 2
Debug: ft2232.c:1732 olimex_jtag_init(): 80 08 1b
Debug: ft2232.c:1775 olimex_jtag_init(): 82 09 0f
Debug: ft2232.c:253 ft2232_speed(): 86 03 00
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST asserted
Debug: jtag.c:1197 jtag_reset_callback(): -
Debug: jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4
Debug: openocd.c:113 main(): jtag init complete
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 4
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST released
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 0
Debug: embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000005
Debug: arm7_9_common.c:707 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST asserted
Warning: arm7_9_common.c:734 arm7_9_assert_reset(): srst resets test logic, too
Debug: ft2232.c:993 olimex_jtag_reset(): trst: 1, srst: 1, high_output: 0x02, high_direction: 0x0f
Debug: arm7_9_common.c:773 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST released
Debug: ft2232.c:993 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: openocd.c:117 main(): target init complete
Debug: openocd.c:121 main(): flash init complete
Debug: openocd.c:125 main(): NAND init complete
Debug: openocd.c:129 main(): pld init complete
Debug: gdb_server.c:1451 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 1
Debug: arm7_9_common.c:929 arm7_9_halt(): target->state: running
Debug: embeddedice.c:384 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:384 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:384 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:384 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:671 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: embeddedice.c:384 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:1047 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:1079 arm7_9_debug_entry(): target entered debug state in Undefined mode
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x00000020
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x40000200
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0x00000067
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x00000024
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r4: 0x00000000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r5: 0xe01fc040
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r6: 0x9e67fd9e
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r7: 0x067ba725
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r8: 0xa2e81794
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r9: 0x00000000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r10: 0x2109a2da
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r11: 0x40007ed8
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0x40007edc
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r13: 0x40007ecc
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r14: 0x000001e0
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x000002f4
Debug: arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x2f4
Debug: target.c:469 target_call_event_callbacks(): target event 0
If there’s any more info needed just let me know. Cheers.
-Shane.
