Debug: 14 0 command.c:82 script_command(): script_command - fast
Debug: 15 0 command.c:99 script_command(): script_command - fast, argv[0]=ocd_fast
Debug: 16 0 command.c:99 script_command(): script_command - fast, argv[1]=disable
Debug: 18 0 command.c:82 script_command(): script_command - jtag_speed
Debug: 19 0 command.c:99 script_command(): script_command - jtag_speed, argv[0]=ocd_jtag_speed
Debug: 20 0 command.c:99 script_command(): script_command - jtag_speed, argv[1]=3
Debug: 21 0 jtag.c:1940 handle_jtag_speed_command(): handle jtag speed
User: 22 0 command.c:363 command_print(): jtag_speed: 3
Debug: 24 0 command.c:82 script_command(): script_command - jtag_nsrst_delay
Debug: 25 0 command.c:99 script_command(): script_command - jtag_nsrst_delay, argv[0]=ocd_jtag_nsrst_delay
Debug: 26 0 command.c:99 script_command(): script_command - jtag_nsrst_delay, argv[1]=200
Debug: 28 0 command.c:82 script_command(): script_command - jtag_ntrst_delay
Debug: 29 0 command.c:99 script_command(): script_command - jtag_ntrst_delay, argv[0]=ocd_jtag_ntrst_delay
Debug: 30 0 command.c:99 script_command(): script_command - jtag_ntrst_delay, argv[1]=200
Debug: 32 0 command.c:82 script_command(): script_command - reset_config
Debug: 33 0 command.c:99 script_command(): script_command - reset_config, argv[0]=ocd_reset_config
Debug: 34 0 command.c:99 script_command(): script_command - reset_config, argv[1]=trst_and_srst
Debug: 35 0 command.c:99 script_command(): script_command - reset_config, argv[2]=srst_pulls_trst
Debug: 37 0 command.c:82 script_command(): script_command - jtag_device
Debug: 38 0 command.c:99 script_command(): script_command - jtag_device, argv[0]=ocd_jtag_device
Debug: 39 0 command.c:99 script_command(): script_command - jtag_device, argv[1]=4
Debug: 40 0 command.c:99 script_command(): script_command - jtag_device, argv[2]=0x1
Debug: 41 0 command.c:99 script_command(): script_command - jtag_device, argv[3]=0xf
Debug: 42 0 command.c:99 script_command(): script_command - jtag_device, argv[4]=0xe
Debug: 43 0 target.c:3859 jim_target(): Target command params:
Debug: 44 0 target.c:3860 jim_target(): target create target0 arm7tdmi -endian little -chain-position 0 -variant arm7tdmi-s_r4
Debug: 46 0 command.c:82 script_command(): script_command - working_area
Debug: 47 0 command.c:99 script_command(): script_command - working_area, argv[0]=ocd_working_area
Debug: 48 0 command.c:99 script_command(): script_command - working_area, argv[1]=0
Debug: 49 0 command.c:99 script_command(): script_command - working_area, argv[2]=0x40000000
Debug: 50 0 command.c:99 script_command(): script_command - working_area, argv[3]=0x4000
Debug: 51 0 command.c:99 script_command(): script_command - working_area, argv[4]=nobackup
Debug: 53 0 command.c:82 script_command(): script_command - bank
Debug: 54 0 command.c:99 script_command(): script_command - bank, argv[0]=ocd_flash_bank
Debug: 55 0 command.c:99 script_command(): script_command - bank, argv[1]=lpc2000
Debug: 56 0 command.c:99 script_command(): script_command - bank, argv[2]=0x0
Debug: 57 0 command.c:99 script_command(): script_command - bank, argv[3]=0x40000
Debug: 58 0 command.c:99 script_command(): script_command - bank, argv[4]=0
Debug: 59 0 command.c:99 script_command(): script_command - bank, argv[5]=0
Debug: 60 0 command.c:99 script_command(): script_command - bank, argv[6]=0
Debug: 61 0 command.c:99 script_command(): script_command - bank, argv[7]=lpc2000_v1
Debug: 62 0 command.c:99 script_command(): script_command - bank, argv[8]=14746
Debug: 63 0 command.c:99 script_command(): script_command - bank, argv[9]=calc_checksum
Debug: 65 0 command.c:82 script_command(): script_command - gdb_flash_program
Debug: 66 0 command.c:99 script_command(): script_command - gdb_flash_program, argv[0]=ocd_gdb_flash_program
Debug: 67 0 command.c:99 script_command(): script_command - gdb_flash_program, argv[1]=enable
Debug: 69 0 command.c:82 script_command(): script_command - init
Debug: 70 0 command.c:99 script_command(): script_command - init, argv[0]=ocd_init
Debug: 71 0 openocd.c:133 handle_init_command(): target init complete
Debug: 72 0 ft2232.c:1382 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'oocdlink' layout (0403:6010)
Debug: 73 31 ft2232.c:1471 ft2232_init_ftd2xx(): current latency timer: 2
Debug: 74 31 ft2232.c:1737 jtagkey_init(): 80 08 1b
Debug: 75 31 ft2232.c:1795 jtagkey_init(): 82 06 0f
Debug: 76 31 ft2232.c:256 ft2232_speed(): 86 03 00
Debug: 77 31 openocd.c:140 handle_init_command(): jtag interface init complete
Debug: 78 31 jtag.c:1621 jtag_init_inner(): Init JTAG chain
Debug: 79 31 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 80 31 jtag.c:1301 jtag_reset_callback(): -
Debug: 81 31 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 82 31 jtag.c:1301 jtag_reset_callback(): -
Info: 83 31 jtag.c:1410 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Debug: 84 31 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 85 31 jtag.c:1301 jtag_reset_callback(): -
Debug: 86 31 openocd.c:146 handle_init_command(): jtag init complete
Debug: 87 31 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000000
Debug: 88 31 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 89 31 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
Debug: 90 31 openocd.c:149 handle_init_command(): jtag examine complete
Debug: 91 31 openocd.c:155 handle_init_command(): flash init complete
Debug: 92 31 openocd.c:159 handle_init_command(): mflash init complete
Debug: 93 31 openocd.c:163 handle_init_command(): NAND init complete
Debug: 94 31 openocd.c:167 handle_init_command(): pld init complete
Debug: 95 47 gdb_server.c:2168 gdb_init(): gdb service for target arm7tdmi at port 3333
Warning: 96 47 tcl_server.c:178 tcl_init(): no tcl port specified, using default port 6666
Debug: 98 47 command.c:82 script_command(): script_command - fast
Debug: 99 47 command.c:99 script_command(): script_command - fast, argv[0]=ocd_fast
Debug: 100 47 command.c:99 script_command(): script_command - fast, argv[1]=enable
Debug: 102 47 command.c:82 script_command(): script_command - jtag_khz
Debug: 103 47 command.c:99 script_command(): script_command - jtag_khz, argv[0]=ocd_jtag_khz
Debug: 104 47 command.c:99 script_command(): script_command - jtag_khz, argv[1]=500
Debug: 105 47 jtag.c:1965 handle_jtag_khz_command(): handle jtag khz
Debug: 106 47 jtag.c:1973 handle_jtag_khz_command(): have interface set up
Debug: 107 47 ft2232.c:256 ft2232_speed(): 86 0b 00
User: 108 47 command.c:363 command_print(): jtag_khz: 500
Debug: 110 47 command.c:82 script_command(): script_command - debug_level
Debug: 111 47 command.c:99 script_command(): script_command - debug_level, argv[0]=ocd_debug_level
Debug: 112 47 command.c:99 script_command(): script_command - debug_level, argv[1]=3
Debug: 114 47 command.c:82 script_command(): script_command - init
Debug: 115 47 command.c:99 script_command(): script_command - init, argv[0]=ocd_init
Info: 116 5250 server.c:84 add_connection(): accepting 'telnet' connection from 0
Debug: 118 22141 command.c:82 script_command(): script_command - jtag_khz
Debug: 119 22141 command.c:99 script_command(): script_command - jtag_khz, argv[0]=ocd_jtag_khz
Debug: 120 22141 command.c:99 script_command(): script_command - jtag_khz, argv[1]=100
Debug: 121 22141 jtag.c:1965 handle_jtag_khz_command(): handle jtag khz
Debug: 122 22141 jtag.c:1973 handle_jtag_khz_command(): have interface set up
Debug: 123 22141 ft2232.c:256 ft2232_speed(): 86 3b 00
User: 124 22141 command.c:363 command_print(): jtag_khz: 100
Debug: 126 22141 command.c:82 script_command(): script_command - reset
Debug: 127 22141 command.c:99 script_command(): script_command - reset, argv[0]=ocd_reset
Debug: 128 22141 command.c:99 script_command(): script_command - reset, argv[1]=run
Debug: 129 22141 target.c:3859 jim_target(): Target command params:
Debug: 130 22141 target.c:3860 jim_target(): target names
Debug: 131 22141 target.c:2995 target_handle_event(): event: 9 reset-start - no action
Debug: 132 22141 jtag.c:1658 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / TLR
Debug: 133 22141 jtag.c:1003 jtag_add_reset(): SRST line released
Debug: 134 22141 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 135 22141 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 136 22141 jtag.c:1301 jtag_reset_callback(): -
Debug: 137 22141 jtag.c:999 jtag_add_reset(): SRST line asserted
Debug: 138 22141 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 139 22141 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 140 22141 jtag.c:1301 jtag_reset_callback(): -
Debug: 141 22141 jtag.c:1003 jtag_add_reset(): SRST line released
Debug: 142 22141 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 0, high_output: 0x04, high_direction: 0x0f
Debug: 143 22375 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 144 22375 ft2232.c:1012 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x06, high_direction: 0x0f
Debug: 146 22891 jtag.c:1621 jtag_init_inner(): Init JTAG chain
Debug: 147 22891 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 148 22891 jtag.c:1301 jtag_reset_callback(): -
Info: 149 22906 jtag.c:1410 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Debug: 150 22906 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 151 22906 jtag.c:1301 jtag_reset_callback(): -
Debug: 152 22906 target.c:3859 jim_target(): Target command params:
Debug: 153 22906 target.c:3860 jim_target(): target names
Debug: 154 22906 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000000
Debug: 155 22906 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 156 22906 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
Debug: 157 22906 target.c:3859 jim_target(): Target command params:
Debug: 158 22906 target.c:3860 jim_target(): target names
Debug: 159 22906 target.c:2995 target_handle_event(): event: 10 reset-assert-pre - no action
Debug: 160 22906 arm7_9_common.c:814 arm7_9_assert_reset(): target->state: running
Debug: 161 22906 jtag.c:999 jtag_add_reset(): SRST line asserted
Debug: 162 22906 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 163 22906 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 164 22906 jtag.c:1301 jtag_reset_callback(): -
Debug: 165 22906 target.c:2995 target_handle_event(): event: 11 reset-assert-post - no action
Debug: 166 22906 target.c:3859 jim_target(): Target command params:
Debug: 167 22906 target.c:3860 jim_target(): target names
Debug: 168 22906 target.c:2995 target_handle_event(): event: 12 reset-deassert-pre - no action
Debug: 169 22906 arm7_9_common.c:876 arm7_9_deassert_reset(): target->state: reset
Debug: 170 22906 jtag.c:1003 jtag_add_reset(): SRST line released
Debug: 171 22906 target.c:2995 target_handle_event(): event: 13 reset-deassert-post - no action
Debug: 172 22906 target.c:3859 jim_target(): Target command params:
Debug: 173 22906 target.c:3860 jim_target(): target names
Debug: 174 22906 target.c:2995 target_handle_event(): event: 19 reset-end - no action
Debug: 175 22906 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 176 22969 ft2232.c:1012 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x06, high_direction: 0x0f
Debug: 179 23406 command.c:82 script_command(): script_command - sleep
Debug: 180 23406 command.c:99 script_command(): script_command - sleep, argv[0]=ocd_sleep
Debug: 181 23406 command.c:99 script_command(): script_command - sleep, argv[1]=100
Debug: 183 23516 command.c:82 script_command(): script_command - reset
Debug: 184 23516 command.c:99 script_command(): script_command - reset, argv[0]=ocd_reset
Debug: 185 23516 command.c:99 script_command(): script_command - reset, argv[1]=halt
Debug: 186 23516 target.c:3859 jim_target(): Target command params:
Debug: 187 23516 target.c:3860 jim_target(): target names
Debug: 188 23516 target.c:2995 target_handle_event(): event: 9 reset-start - no action
Debug: 189 23516 jtag.c:1658 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / TLR
Debug: 190 23516 jtag.c:1003 jtag_add_reset(): SRST line released
Debug: 191 23516 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 192 23516 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 193 23516 jtag.c:1301 jtag_reset_callback(): -
Debug: 194 23516 jtag.c:999 jtag_add_reset(): SRST line asserted
Debug: 195 23516 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 196 23516 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 197 23516 jtag.c:1301 jtag_reset_callback(): -
Debug: 198 23516 jtag.c:1003 jtag_add_reset(): SRST line released
Debug: 199 23516 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 0, high_output: 0x04, high_direction: 0x0f
Debug: 201 23797 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 202 23797 ft2232.c:1012 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x06, high_direction: 0x0f
Debug: 203 24219 jtag.c:1621 jtag_init_inner(): Init JTAG chain
Debug: 204 24219 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 205 24219 jtag.c:1301 jtag_reset_callback(): -
Info: 206 24234 jtag.c:1410 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Debug: 207 24234 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 208 24234 jtag.c:1301 jtag_reset_callback(): -
Debug: 209 24234 target.c:3859 jim_target(): Target command params:
Debug: 210 24234 target.c:3860 jim_target(): target names
Debug: 211 24234 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000000
Debug: 212 24234 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 213 24234 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
Debug: 214 24234 target.c:3859 jim_target(): Target command params:
Debug: 215 24234 target.c:3860 jim_target(): target names
Debug: 216 24234 target.c:2995 target_handle_event(): event: 10 reset-assert-pre - no action
Debug: 217 24234 arm7_9_common.c:814 arm7_9_assert_reset(): target->state: running
Debug: 218 24234 embeddedice.c:401 embeddedice_write_reg(): 8: 0x00000000
Debug: 219 24234 embeddedice.c:401 embeddedice_write_reg(): 9: 0x00000003
Debug: 220 24234 embeddedice.c:401 embeddedice_write_reg(): 11: 0xffffffff
Debug: 221 24234 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000100
Debug: 222 24234 embeddedice.c:401 embeddedice_write_reg(): 13: 0x000000f7
Debug: 223 24234 jtag.c:999 jtag_add_reset(): SRST line asserted
Debug: 224 24234 jtag.c:1022 jtag_add_reset(): TRST line asserted
Debug: 225 24234 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 226 24234 jtag.c:1301 jtag_reset_callback(): -
Debug: 227 24234 target.c:2995 target_handle_event(): event: 11 reset-assert-post - no action
Debug: 228 24234 target.c:3859 jim_target(): Target command params:
Debug: 229 24234 target.c:3860 jim_target(): target names
Debug: 230 24234 target.c:2995 target_handle_event(): event: 12 reset-deassert-pre - no action
Debug: 231 24234 arm7_9_common.c:876 arm7_9_deassert_reset(): target->state: reset
Debug: 232 24234 jtag.c:1003 jtag_add_reset(): SRST line released
Warning: 233 24234 arm7_9_common.c:884 arm7_9_deassert_reset(): srst pulls trst - can not reset into halted mode. Issuing halt after reset.
Debug: 234 24234 ft2232.c:1012 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 236 24297 ft2232.c:1012 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x06, high_direction: 0x0f
Debug: 238 24812 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000000
Debug: 239 24812 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 240 24812 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
Debug: 241 24812 arm7_9_common.c:1061 arm7_9_halt(): target->state: running
Debug: 242 24812 embeddedice.c:401 embeddedice_write_reg(): 9: 0xffffffff
Debug: 243 24812 embeddedice.c:401 embeddedice_write_reg(): 11: 0xffffffff
Debug: 244 24812 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000100
Debug: 245 24812 embeddedice.c:401 embeddedice_write_reg(): 13: 0x000000f7
Debug: 246 24812 target.c:2995 target_handle_event(): event: 13 reset-deassert-post - no action
Debug: 247 24812 target.c:3859 jim_target(): Target command params:
Debug: 248 24812 target.c:3860 jim_target(): target names
Debug: 249 24812 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 250 24812 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 251 24812 arm7_9_common.c:1160 arm7_9_debug_entry(): target entered debug from ARM state
Debug: 252 24828 arm7_9_common.c:1192 arm7_9_debug_entry(): target entered debug state in Abort mode
Debug: 253 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r0: 0x942802b4
Debug: 254 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r1: 0x40000200
Debug: 255 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r2: 0x00000023
Debug: 256 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r3: 0x0aaa0848
Debug: 257 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r4: 0x00000000
Debug: 258 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r5: 0xe01fc040
Debug: 259 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r6: 0x4c23a692
Debug: 260 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r7: 0x2a477c24
Debug: 261 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r8: 0xa0a29338
Debug: 262 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r9: 0x9201c562
Debug: 263 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r10: 0x100ec418
Debug: 264 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r11: 0x40003eb0
Debug: 265 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r12: 0x40003eb4
Debug: 266 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r13: 0x40003ed8
Debug: 267 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r14: 0x0000201c
Debug: 268 24828 arm7_9_common.c:1223 arm7_9_debug_entry(): r15: 0x0000061c
Debug: 269 24828 arm7_9_common.c:1229 arm7_9_debug_entry(): entered debug state at PC 0x61c
Debug: 270 24844 target.c:709 target_call_event_callbacks(): target event 4 (early-halted)
Debug: 271 24844 target.c:2995 target_handle_event(): event: 4 early-halted - no action
Debug: 272 24844 target.c:709 target_call_event_callbacks(): target event 5 (halted)
Debug: 273 24844 target.c:2995 target_handle_event(): event: 5 halted - no action
User: 274 24844 target.c:965 target_arch_state(): target state: halted
User: 275 24844 armv4_5.c:317 armv4_5_arch_state(): target halted in ARM state due to debug-request, current mode: Abort
cpsr: 0x200000d7 pc: 0x0000061c
Debug: 276 24844 target.c:3859 jim_target(): Target command params:
Debug: 277 24844 target.c:3860 jim_target(): target names
Debug: 278 24844 target.c:2995 target_handle_event(): event: 19 reset-end - no action
Debug: 280 24844 command.c:82 script_command(): script_command - wait_halt
Debug: 281 24844 command.c:99 script_command(): script_command - wait_halt, argv[0]=ocd_wait_halt
Debug: 282 24844 command.c:99 script_command(): script_command - wait_halt, argv[1]=2
Debug: 284 24844 command.c:82 script_command(): script_command - mww
Debug: 285 24844 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 286 24844 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC080
Debug: 287 24844 command.c:99 script_command(): script_command - mww, argv[2]=0x01
Debug: 288 24844 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 289 24859 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 291 24875 command.c:82 script_command(): script_command - mww
Debug: 292 24875 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 293 24875 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC08C
Debug: 294 24875 command.c:99 script_command(): script_command - mww, argv[2]=0xAA
Debug: 295 24875 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 296 24891 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 298 24891 command.c:82 script_command(): script_command - mww
Debug: 299 24891 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 300 24891 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC08C
Debug: 301 24891 command.c:99 script_command(): script_command - mww, argv[2]=0x55
Debug: 302 24891 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 303 24906 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 305 24922 command.c:82 script_command(): script_command - mww
Debug: 306 24922 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 307 24922 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC080
Debug: 308 24922 command.c:99 script_command(): script_command - mww, argv[2]=0x00
Debug: 309 24922 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 310 24937 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 312 24937 command.c:82 script_command(): script_command - mww
Debug: 313 24937 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 314 24937 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC08C
Debug: 315 24937 command.c:99 script_command(): script_command - mww, argv[2]=0xAA
Debug: 316 24937 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 317 24953 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 319 24969 command.c:82 script_command(): script_command - mww
Debug: 320 24969 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 321 24969 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC08C
Debug: 322 24969 command.c:99 script_command(): script_command - mww, argv[2]=0x55
Debug: 323 24969 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 324 24984 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 326 24984 command.c:82 script_command(): script_command - mww
Debug: 327 24984 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 328 24984 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC104
Debug: 329 24984 command.c:99 script_command(): script_command - mww, argv[2]=0x00
Debug: 330 24984 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 331 25000 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 333 25016 command.c:82 script_command(): script_command - mww
Debug: 334 25016 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 335 25016 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC10C
Debug: 336 25016 command.c:99 script_command(): script_command - mww, argv[2]=0x00
Debug: 337 25016 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 338 25031 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 340 25031 command.c:82 script_command(): script_command - mww
Debug: 341 25031 command.c:99 script_command(): script_command - mww, argv[0]=ocd_mww
Debug: 342 25031 command.c:99 script_command(): script_command - mww, argv[1]=0xE01FC040
Debug: 343 25031 command.c:99 script_command(): script_command - mww, argv[2]=0x01
Debug: 344 25031 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 345 25047 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 347 25062 command.c:82 script_command(): script_command - sleep
Debug: 348 25062 command.c:99 script_command(): script_command - sleep, argv[0]=ocd_sleep
Debug: 349 25062 command.c:99 script_command(): script_command - sleep, argv[1]=100
Debug: 351 25172 command.c:82 script_command(): script_command - jtag_khz
Debug: 352 25172 command.c:99 script_command(): script_command - jtag_khz, argv[0]=ocd_jtag_khz
Debug: 353 25172 command.c:99 script_command(): script_command - jtag_khz, argv[1]=500
Debug: 354 25172 jtag.c:1965 handle_jtag_khz_command(): handle jtag khz
Debug: 355 25172 jtag.c:1973 handle_jtag_khz_command(): have interface set up
Debug: 356 25172 ft2232.c:256 ft2232_speed(): 86 0b 00
User: 357 25172 command.c:363 command_print(): jtag_khz: 500
Debug: 359 25172 command.c:82 script_command(): script_command - probe
Debug: 360 25172 command.c:99 script_command(): script_command - probe, argv[0]=ocd_flash_probe
Debug: 361 25172 command.c:99 script_command(): script_command - probe, argv[1]=0
User: 362 25172 command.c:363 command_print(): flash 'lpc2000' found at 0x00000000
Debug: 364 25172 command.c:82 script_command(): script_command - write_image
Debug: 365 25172 command.c:99 script_command(): script_command - write_image, argv[0]=ocd_flash_write_image
Debug: 366 25172 command.c:99 script_command(): script_command - write_image, argv[1]=erase
Debug: 367 25172 command.c:99 script_command(): script_command - write_image, argv[2]=main.bin
Debug: 368 25172 command.c:99 script_command(): script_command - write_image, argv[3]=0x00
User: 369 25172 command.c:363 command_print(): auto erase enabled
Debug: 370 25172 configuration.c:88 find_file(): found main.bin
Debug: 371 25172 configuration.c:88 find_file(): found main.bin
Debug: 372 25172 target.c:832 target_alloc_working_area(): allocating new working area
Debug: 373 25172 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 374 25172 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 375 25172 armv4_5.c:527 armv4_5_run_algorithm_inner(): Running algorithm
Debug: 376 25172 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: 377 25187 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d7, rot: 0, spsr: 0
Debug: 378 25187 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: 379 25187 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d7, rot: 0, spsr: 0
Debug: 380 25187 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: 381 25187 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d7, rot: 0, spsr: 0
Debug: 382 25187 target.c:981 target_write_buffer(): writing buffer of 24 byte at 0x40000008
Debug: 383 25187 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 384 25187 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 385 25203 target.c:981 target_write_buffer(): writing buffer of 12 byte at 0x40000020
Debug: 386 25203 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Debug: 387 25203 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000005
Debug: 388 25203 armv4_5.c:594 armv4_5_run_algorithm_inner(): setting core_mode: 0x13
Debug: 389 25203 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
Debug: 390 25203 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
Debug: 391 25203 embeddedice.c:401 embeddedice_write_reg(): 8: 0x40000004
Debug: 392 25203 embeddedice.c:401 embeddedice_write_reg(): 9: 0x00000003
Debug: 393 25203 embeddedice.c:401 embeddedice_write_reg(): 11: 0xffffffff
Debug: 394 25203 embeddedice.c:401 embeddedice_write_reg(): 13: 0x000000f7
Debug: 395 25203 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000100
Debug: 396 25203 breakpoints.c:93 breakpoint_add(): added hardware breakpoint at 0x40000004 of length 0x00000004
Debug: 397 25203 arm7_9_common.c:1535 arm7_9_resume(): -
Debug: 398 25203 embeddedice.c:401 embeddedice_write_reg(): 8: 0x40000004
Debug: 399 25203 embeddedice.c:401 embeddedice_write_reg(): 9: 0x00000003
Debug: 400 25203 embeddedice.c:401 embeddedice_write_reg(): 11: 0xffffffff
Debug: 401 25203 embeddedice.c:401 embeddedice_write_reg(): 13: 0x000000f7
Debug: 402 25203 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000100
Debug: 403 25203 arm7_9_common.c:1353 arm7_9_restore_context(): -
Debug: 404 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining User mode
Debug: 405 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r0
Debug: 406 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r1
Debug: 407 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r2
Debug: 408 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r3
Debug: 409 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r4
Debug: 410 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r5
Debug: 411 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r6
Debug: 412 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r12
Debug: 413 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 414 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: cpsr
Debug: 415 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 0 of mode User with value 0x40000008
Debug: 416 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 1 of mode User with value 0x40000020
Debug: 417 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 2 of mode User with value 0x00000023
Debug: 418 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 3 of mode User with value 0x0aaa0848
Debug: 419 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 4 of mode User with value 0x00000000
Debug: 420 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 5 of mode User with value 0xe01fc040
Debug: 421 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 6 of mode User with value 0x4c23a692
Debug: 422 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 12 of mode User with value 0x7ffffff1
Debug: 423 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining FIQ mode
Debug: 424 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 425 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining IRQ mode
Debug: 426 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 427 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining Supervisor mode
Debug: 428 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: r13_svc
Debug: 429 25203 arm7_9_common.c:1393 arm7_9_restore_context(): require mode change
Debug: 430 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: lr_svc
Debug: 431 25203 arm7_9_common.c:1393 arm7_9_restore_context(): require mode change
Debug: 432 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 433 25203 arm7tdmi.c:500 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: 434 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 13 of mode Supervisor with value 0x400000ac
Debug: 435 25203 arm7_9_common.c:1434 arm7_9_restore_context(): writing register 14 of mode Supervisor with value 0x40000004
Debug: 436 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining Abort mode
Debug: 437 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 438 25203 arm7_9_common.c:1372 arm7_9_restore_context(): examining Undefined mode
Debug: 439 25203 arm7_9_common.c:1386 arm7_9_restore_context(): examining dirty reg: pc
Debug: 440 25203 arm7_9_common.c:1467 arm7_9_restore_context(): writing cpsr with value 0x200000d3
Debug: 441 25203 arm7tdmi.c:469 arm7tdmi_write_xpsr(): xpsr: 200000d3, spsr: 0
Debug: 442 25203 arm7_9_common.c:1474 arm7_9_restore_context(): writing PC with value 0x40000000
Debug: 443 25203 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Error: 444 25203 ft2232.c:177 ft2232_write(): FT_Write returned: 4
Error: 445 25203 ft2232.c:412 ft2232_send_and_recv(): couldn't write MPSSE commands to FT2232
Debug: 446 25219 armv4_5.c:527 armv4_5_run_algorithm_inner(): Running algorithm
Debug: 447 25219 target.c:981 target_write_buffer(): writing buffer of 24 byte at 0x40000008
Debug: 448 25219 embeddedice.c:401 embeddedice_write_reg(): 0: 0x00000004
Warning: 449 25219 jtag.c:1217 jtag_check_value(): value captured during scan didn't pass the requested check: captured: 0x0f check_value: 0x01 check_mask: 0x0f
Warning: 450 25219 jtag.c:1177 jtag_read_buffer(): in_handler reported a failed check
Warning: 451 25219 lpc2000.c:461 lpc2000_erase(): lpc2000 erase sectors returned 15645168
Error: 452 25219 flash.c:124 flash_driver_erase(): failed erasing sectors 0 to 0 (-902)
Debug: 453 25219 command.c:407 run_command(): Command failed with error code -902
User: 454 25219 command.c:607 openocd_jim_vfprintf(): Runtime error, file "?", line 1:
User: 455 25219 command.c:607 openocd_jim_vfprintf():
User: 456 25219 command.c:607 openocd_jim_vfprintf(): In procedure 'mt_flash_bin' called at file "command.c", line 436
User: 457 25219 command.c:607 openocd_jim_vfprintf(): In procedure 'flash' called at file ".\oocd_cfg\lpc2124.cfg", line 62
User: 458 25219 command.c:607 openocd_jim_vfprintf(): In procedure 'unknown' called at file "?", line 1
Debug: 459 39187 telnet_server.c:406 telnet_input(): unhandled nonprintable: 03
