Dear Michael,
Here is my working environemnt
OLIMEX LPC2148 header board and KEIL MCB2140 EVL board (i am not using my own design)
OLIMEX ARM-USB-OCD JTAG tool
Eclipse 3.3 Platform with OpenOCD version “openocd-2007re204”
I just installed the software listed in http://www.yagarto.de/ website.
And by using the sampel code LPC2148Test which is download from this http://www.yagarto.de/howto/yagarto2/index.html link and follow the procedure to create project in eclipse platform and compiled the code.
Also i run the code in dos prompt and the result is same.
Here is the log file,
D:\Yagarto\LPC214~1>openocd-ftd2xx -d3 -lopenocd.log -f .\prj\openocd.cfg
Info: openocd.c:93 main(): Open On-Chip Debugger (2007-09-05 09:00 CEST)
Debug: jtag.c:1407 jtag_init(): -
Debug: ft2232.c:1296 ft2232_init_ftd2xx(): ‘ft2232’ interface using FTD2XX with ‘olimex-jtag’ layout (15ba:0003)
Debug: ft2232.c:1385 ft2232_init_ftd2xx(): current latency timer: 2
Debug: ft2232.c:1732 olimex_jtag_init(): 80 08 1b
Debug: ft2232.c:1775 olimex_jtag_init(): 82 09 0f
Debug: ft2232.c:253 ft2232_speed(): 86 02 00
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST asserted
Debug: jtag.c:1197 jtag_reset_callback(): -
Error: jtag.c:1253 jtag_examine_chain(): JTAG communication failure, check connection, JTAG interface, target power etc.
Error: jtag.c:1440 jtag_init(): trying to validate configured JTAG chain anyway…
Debug: openocd.c:113 main(): jtag init complete
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 4
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST released
Error: embeddedice.c:181 embeddedice_build_reg_cache(): unknown EmbeddedICE version (comms ctrl: 0x00000000)
Debug: arm7_9_common.c:707 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST asserted
Warning: arm7_9_common.c:734 arm7_9_assert_reset(): srst resets test logic, too
Debug: ft2232.c:993 olimex_jtag_reset(): trst: 1, srst: 1, high_output: 0x02, high_direction: 0x0f
Debug: arm7_9_common.c:773 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST released
Debug: ft2232.c:993 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: openocd.c:117 main(): target init complete
Debug: openocd.c:121 main(): flash init complete
Debug: openocd.c:125 main(): NAND init complete
Debug: openocd.c:129 main(): pld init complete
Debug: gdb_server.c:1451 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 1
Debug: arm7_9_common.c:929 arm7_9_halt(): target->state: running
Debug: embeddedice.c:384 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:384 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:384 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:384 embeddedice_write_reg(): 13: 0x000000f7
And it is keep going, i just break console window…
Karuna.
