Getting a little frustrated here. Following on from this thread:
I have got past the lock issue by manually issuing the FLASH instructions from a script. It seems that there is some issue because Atmel FLASH has the same id as Intel FLASH so it uses the Intel routines which shouldnt be a problem as the statemachines and commands are all the same except for burst programming mode.
Now Im having numerous problems. If I write a few words of flash then all is well but if I try and write_image to a single sector or multiple sectors I get both some sectors not being written to and others being incorrect.
Telnet Connection
Open On-Chip Debugger
> script boot.script
dcc downloads are enabled
JTAG device found: 0x05b0203f (Manufacturer: 0x01f, Part: 0x5b02, Version: 0x0)
target state: halted
target halted in ARM state due to debug request, current mode: Abort
cpsr: 0xf00000d7 pc: 0x00000000
MMU: disabled, D-Cache: disabled, I-Cache: disabled
expected one protection register field, but found 255
flash 'cfi' found at 0x10000000
erased sectors 0 through 9 on flash bank 0 in 8.937500s
Using target buffer at 0x00200038 and of size 0x8000
Write 0x04b0 bytes to flash at 0x10000000
Fixup 1 unaligned tail bytes
wrote 1201 byte from file 0x10000000.bin in 9.390625s (0.124896 kb/s)
target halted in ARM state due to breakpoint, current mode: Abort
cpsr: 0x300000d7 pc: 0x00000000
> mdw 0x10000000 0x200
target not halted
Failure examining memory
> halt
waiting for target halted...
target halted in ARM state due to debug request, current mode: Supervisor
cpsr: 0x600000d3 pc: 0x00000000
timeout waiting for SYSCOMP & DBGACK, last DBG_STATUS: 5
openOCD Log
Open On-Chip Debugger (2008-04-19 12:00) svn: 592
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Debug: 5 0 command.c:383 command_run_line(): script debug.cfg
Debug: 6 0 configuration.c:87 open_file_from_path(): opened debug.cfg
Debug: 7 0 command.c:383 command_run_line(): telnet_port 4444
Debug: 8 0 command.c:383 command_run_line(): gdb_port 3333
Debug: 9 0 command.c:383 command_run_line(): deamon_starup attach
Info: 10 0 options.c:50 configuration_output_handler(): Command deamon_starup not found
Debug: 11 0 command.c:383 command_run_line(): interface ft2232
Debug: 12 0 command.c:383 command_run_line(): ft2232_device_desc "Amontec JTAGkey A"
Debug: 13 0 command.c:383 command_run_line(): ft2232_layout jtagkey
Debug: 14 0 command.c:383 command_run_line(): ft2232_latency 50
Debug: 15 0 command.c:383 command_run_line(): ft2232_vid_pid 0x0403 0xcff8
Debug: 16 0 command.c:383 command_run_line(): jtag_speed 0
Debug: 17 0 jtag.c:1843 handle_jtag_speed_command(): handle jtag speed
Info: 18 0 options.c:50 configuration_output_handler(): jtag_speed: 0, 0
Debug: 19 0 command.c:383 command_run_line(): reset_config trst_and_srst srst_pulls_trst
Debug: 20 0 command.c:383 command_run_line(): jtag_device 4 0x1 0xf 0xe
Debug: 21 0 command.c:383 command_run_line(): jtag_nsrst_delay 250
Debug: 22 0 command.c:383 command_run_line(): jtag_ntrst_delay 250
Debug: 23 0 command.c:383 command_run_line(): target arm920t little reset_halt
0 arm920t
Debug: 24 0 arm920t.c:741 arm920t_target_command(): chain_pos: 0, variant: arm920t
Debug: 25 0 command.c:383 command_run_line(): working_area 0 0x200000 0x100000 nobackup
Debug: 26 0 command.c:383 command_run_line(): run_and_halt_time 0 5000
Debug: 27 0 command.c:383 command_run_line(): daemon_startup reset
Info: 28 0 options.c:50 configuration_output_handler(): Open On-Chip Debugger (2008-04-19 12:00) svn: 592
Debug: 29 0 command.c:383 command_run_line(): flash bank cfi 0x10000000 0x800000 2 2
0
Debug: 30 0 command.c:383 command_run_line(): init
Debug: 31 0 openocd.c:102 handle_init_command(): target init complete
Debug: 32 0 ft2232.c:1330 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'jtagkey' layout (0403:cff8)
Debug: 33 47 ft2232.c:1419 ft2232_init_ftd2xx(): current latency timer: 50
Debug: 34 47 ft2232.c:1685 jtagkey_init(): 80 08 1b
Debug: 35 47 ft2232.c:1743 jtagkey_init(): 82 09 0f
Debug: 36 47 ft2232.c:252 ft2232_speed(): 86 00 00
Debug: 37 47 openocd.c:109 handle_init_command(): jtag interface init complete
Debug: 38 47 jtag.c:1526 jtag_init_inner(): Init JTAG chain
Debug: 39 47 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 40 47 jtag.c:1282 jtag_reset_callback(): -
Debug: 41 47 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 42 47 jtag.c:1282 jtag_reset_callback(): -
Info: 43 109 jtag.c:1376 jtag_examine_chain(): JTAG device found: 0x05b0203f (Manufacturer: 0x01f, Part: 0x5b02, Version: 0x0)
Debug: 44 109 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 45 109 jtag.c:1282 jtag_reset_callback(): -
Debug: 46 156 openocd.c:116 handle_init_command(): jtag init complete
Debug: 47 203 openocd.c:119 handle_init_command(): jtag examine complete
Debug: 48 203 openocd.c:126 handle_init_command(): flash init complete
Debug: 49 203 openocd.c:130 handle_init_command(): NAND init complete
Debug: 50 203 openocd.c:134 handle_init_command(): pld init complete
Debug: 51 203 gdb_server.c:1975 gdb_init(): gdb service for target arm920t at port 3333
Debug: 52 203 command.c:383 command_run_line(): reset
Debug: 53 203 target.c:1813 handle_reset_command(): -
Debug: 54 203 ft2232.c:252 ft2232_speed(): 86 00 00
Debug: 55 203 jtag.c:1570 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / tms
Debug: 56 203 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 57 203 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 58 203 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 59 203 jtag.c:1282 jtag_reset_callback(): -
Debug: 60 203 jtag.c:985 jtag_add_reset(): SRST line asserted
Debug: 61 203 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 62 203 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 63 203 jtag.c:1282 jtag_reset_callback(): -
Debug: 64 203 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 65 203 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 0, high_output: 0x08, high_direction: 0x0f
Debug: 66 453 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 67 453 ft2232.c:960 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: 68 953 jtag.c:1526 jtag_init_inner(): Init JTAG chain
Debug: 69 953 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 70 953 jtag.c:1282 jtag_reset_callback(): -
Info: 71 1000 jtag.c:1376 jtag_examine_chain(): JTAG device found: 0x05b0203f (Manufacturer: 0x01f, Part: 0x5b02, Version: 0x0)
Debug: 72 1000 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 73 1000 jtag.c:1282 jtag_reset_callback(): -
Info: 74 1047 options.c:50 configuration_output_handler(): nSRST pulls nTRST, falling back to "reset run_and_halt"
Debug: 75 1047 arm7_9_common.c:736 arm7_9_assert_reset(): target->state: unknown
Debug: 76 1047 jtag.c:985 jtag_add_reset(): SRST line asserted
Debug: 77 1047 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 78 1047 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 79 1047 jtag.c:1282 jtag_reset_callback(): -
Debug: 80 1047 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 81 1109 arm7_9_common.c:789 arm7_9_deassert_reset(): target->state: reset
Debug: 82 1109 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 83 1109 ft2232.c:960 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: 84 1609 target.c:393 target_process_reset(): Waiting for halted stated as approperiate
Debug: 85 1640 target.c:407 target_process_reset(): Polling target
Debug: 87 2203 target.c:407 target_process_reset(): Polling target
Debug: 89 2750 target.c:407 target_process_reset(): Polling target
Debug: 91 3297 target.c:407 target_process_reset(): Polling target
Debug: 93 3843 target.c:407 target_process_reset(): Polling target
Debug: 95 4390 target.c:407 target_process_reset(): Polling target
Debug: 97 4953 target.c:407 target_process_reset(): Polling target
Debug: 99 5500 target.c:407 target_process_reset(): Polling target
Debug: 101 6047 target.c:407 target_process_reset(): Polling target
Debug: 103 6593 arm7_9_common.c:926 arm7_9_halt(): target->state: running
Debug: 104 6593 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000002
Debug: 105 6593 target.c:407 target_process_reset(): Polling target
Debug: 107 7203 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 108 7203 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 109 7203 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 110 7203 arm7_9_common.c:1044 arm7_9_debug_entry(): target entered debug from ARM state
Debug: 111 7250 arm7_9_common.c:1076 arm7_9_debug_entry(): target entered debug state in Abort mode
Debug: 112 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r0: 0xfffffdff
Debug: 113 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r1: 0x7fbfffff
Debug: 114 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r2: 0xfdfdffef
Debug: 115 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r3: 0xffeff7ff
Debug: 116 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r4: 0xf7bffdff
Debug: 117 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r5: 0xfffffffe
Debug: 118 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r6: 0xfffffdff
Debug: 119 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r7: 0xffffffff
Debug: 120 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r8: 0xffffffff
Debug: 121 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r9: 0xffeffffb
Debug: 122 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r10: 0xffbfffff
Debug: 123 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r11: 0xff6fffff
Debug: 124 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r12: 0x7ffffbff
Debug: 125 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r13: 0xffff77ff
Debug: 126 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r14: 0x00000018
Debug: 127 7250 arm7_9_common.c:1105 arm7_9_debug_entry(): r15: 0x00000010
Debug: 128 7250 arm7_9_common.c:1111 arm7_9_debug_entry(): entered debug state at PC 0x10
Debug: 129 7343 arm920t.c:441 arm920t_post_debug_entry(): cp15_control_reg: 00000078
Debug: 130 8453 arm920t.c:463 arm920t_post_debug_entry(): D FSR: 0x000000da, D FAR: 0xfffffdff, I FSR: 0x000000b6, I FAR: 0x0000
0000
Debug: 131 8453 target.c:706 target_call_event_callbacks(): target event 0
Debug: 132 8453 target.c:407 target_process_reset(): Polling target
Debug: 133 8500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 134 8547 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 135 8547 ft2232.c:252 ft2232_speed(): 86 00 00
Info: 136 8547 server.c:78 add_connection(): accepting 'telnet' connection from 0
Debug: 137 8656 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 138 8750 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 139 8843 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 140 8953 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 141 9047 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 142 9156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 143 9297 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 144 9406 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 145 9500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 146 9593 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 147 9703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 148 9843 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 149 9953 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 150 10047 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 151 10156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 152 10250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 153 10406 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 154 10500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 155 10593 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 156 10703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 157 10797 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 158 10906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 159 11047 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 160 11156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 161 11250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 162 11359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 163 11453 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 164 11609 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 165 11703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 166 11797 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 167 11906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 168 12000 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 169 12109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 170 12250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 171 12359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 172 12453 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 173 12547 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 174 12656 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 175 12797 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 176 12906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 177 13000 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 178 13109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 179 13203 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 180 13359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 181 13453 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 182 13547 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 183 13656 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 184 13750 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 185 13859 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 186 14000 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 187 14109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 188 14203 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 189 14297 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 190 14406 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 191 14547 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 192 14656 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 193 14750 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 194 14859 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 195 14953 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 196 15109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 197 15203 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 198 15297 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 199 15406 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 200 15500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 201 15609 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 202 15750 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 203 15859 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 204 15953 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 205 16047 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 206 16156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 207 16297 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 208 16406 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 209 16500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 210 16609 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 211 16703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 212 16859 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 213 16953 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 214 17062 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 215 17156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 216 17250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 217 17359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 218 17500 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 219 17609 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 220 17703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 221 17812 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 222 17906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 223 18062 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 224 18156 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 225 18250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 226 18359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 227 18453 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 228 18562 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 229 18703 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 230 18812 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 231 18906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 232 19000 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 233 19109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 234 19250 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 235 19359 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 236 19453 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 237 19562 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 238 19656 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 239 19812 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 240 19906 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 241 20000 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 242 20109 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 243 20203 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 244 20218 command.c:383 command_run_line(): script boot.script
Debug: 245 20218 configuration.c:87 open_file_from_path(): opened boot.script
Debug: 246 20218 command.c:383 command_run_line(): arm7_9 dcc_downloads enable
Debug: 247 20218 command.c:383 command_run_line(): reset run_and_halt
Debug: 248 20218 target.c:1813 handle_reset_command(): -
Debug: 249 20218 ft2232.c:252 ft2232_speed(): 86 00 00
Debug: 250 20218 jtag.c:1570 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / tms
Debug: 251 20218 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 252 20218 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 253 20218 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 254 20218 jtag.c:1282 jtag_reset_callback(): -
Debug: 255 20218 jtag.c:985 jtag_add_reset(): SRST line asserted
Debug: 256 20218 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 257 20218 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 258 20218 jtag.c:1282 jtag_reset_callback(): -
Debug: 259 20218 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 260 20218 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 0, high_output: 0x08, high_direction: 0x0f
Debug: 261 20468 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 262 20468 ft2232.c:960 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: 263 20968 jtag.c:1526 jtag_init_inner(): Init JTAG chain
Debug: 264 20968 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 265 20968 jtag.c:1282 jtag_reset_callback(): -
Info: 266 21015 jtag.c:1376 jtag_examine_chain(): JTAG device found: 0x05b0203f (Manufacturer: 0x01f, Part: 0x5b02, Version: 0x
0)
Debug: 267 21015 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 268 21015 jtag.c:1282 jtag_reset_callback(): -
Debug: 269 21062 arm7_9_common.c:736 arm7_9_assert_reset(): target->state: halted
Debug: 270 21062 jtag.c:985 jtag_add_reset(): SRST line asserted
Debug: 271 21062 jtag.c:1008 jtag_add_reset(): TRST line asserted
Debug: 272 21062 jtag.c:319 jtag_call_event_callbacks(): jtag event: JTAG controller reset(tms or TRST)
Debug: 273 21062 jtag.c:1282 jtag_reset_callback(): -
Debug: 274 21062 ft2232.c:960 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: 275 21125 arm7_9_common.c:789 arm7_9_deassert_reset(): target->state: reset
Debug: 276 21125 jtag.c:989 jtag_add_reset(): SRST line released
Debug: 277 21125 ft2232.c:960 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: 278 21625 target.c:393 target_process_reset(): Waiting for halted stated as approperiate
Debug: 279 21656 target.c:407 target_process_reset(): Polling target
Debug: 281 22218 target.c:407 target_process_reset(): Polling target
Debug: 283 22765 target.c:407 target_process_reset(): Polling target
Debug: 285 23312 target.c:407 target_process_reset(): Polling target
Debug: 287 23859 target.c:407 target_process_reset(): Polling target
Debug: 289 24406 target.c:407 target_process_reset(): Polling target
Debug: 291 24968 target.c:407 target_process_reset(): Polling target
Debug: 293 25515 target.c:407 target_process_reset(): Polling target
Debug: 295 26062 target.c:407 target_process_reset(): Polling target
Debug: 297 26609 arm7_9_common.c:926 arm7_9_halt(): target->state: running
Debug: 298 26609 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000007
Debug: 299 26609 target.c:407 target_process_reset(): Polling target
Debug: 301 27172 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 302 27172 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 303 27172 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 304 27172 arm7_9_common.c:1044 arm7_9_debug_entry(): target entered debug from ARM state
Debug: 305 27218 arm7_9_common.c:1076 arm7_9_debug_entry(): target entered debug state in Abort mode
Debug: 306 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r0: 0x000030c4
Debug: 307 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r1: 0x00000000
Debug: 308 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r2: 0xfdfdffef
Debug: 309 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r3: 0xffeff7ff
Debug: 310 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r4: 0xf7bffdff
Debug: 311 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r5: 0xfffffffe
Debug: 312 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r6: 0xfffffdff
Debug: 313 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r7: 0xffffffff
Debug: 314 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r8: 0xffffffff
Debug: 315 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r9: 0xffeffffb
Debug: 316 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r10: 0xffbfffff
Debug: 317 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r11: 0xff6fffff
Debug: 318 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r12: 0x7ffffbff
Debug: 319 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r13: 0xffff77ff
Debug: 320 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r14: 0x00000008
Debug: 321 27218 arm7_9_common.c:1105 arm7_9_debug_entry(): r15: 0x00000000
Debug: 322 27218 arm7_9_common.c:1111 arm7_9_debug_entry(): entered debug state at PC 0x0
Debug: 323 27312 arm920t.c:441 arm920t_post_debug_entry(): cp15_control_reg: 00000078
Debug: 324 28468 arm920t.c:463 arm920t_post_debug_entry(): D FSR: 0x000000da, D FAR: 0xffeff85f, I FSR: 0x000000b6, I FAR: 0x000
00000
Debug: 325 28468 target.c:706 target_call_event_callbacks(): target event 0
User: 326 28468 target.c:936 target_arch_state(): target state: halted
User: 327 28468 arm920t.c:567 arm920t_arch_state(): target halted in ARM state due to debug request, current mode: Abort
Debug: 328 28468 target.c:407 target_process_reset(): Polling target
Debug: 329 28515 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 330 28562 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 331 28562 ft2232.c:252 ft2232_speed(): 86 00 00
Debug: 332 28562 command.c:383 command_run_line(): sleep 5
Debug: 333 28578 command.c:383 command_run_line(): wait_halt 30
Debug: 334 28609 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Debug: 335 28609 command.c:383 command_run_line(): sleep 5
Debug: 336 28625 command.c:383 command_run_line(): poll
Debug: 337 28672 arm7_9_common.c:688 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
User: 338 28672 target.c:936 target_arch_state(): target state: halted
User: 339 28672 arm920t.c:567 arm920t_arch_state(): target halted in ARM state due to debug request, current mode: Abort
Debug: 340 28672 command.c:383 command_run_line(): sleep 2
Debug: 341 28687 command.c:383 command_run_line(): flash probe 0
Debug: 342 28687 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 343 28859 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 344 28922 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 345 29109 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 346 29172 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 347 29359 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 348 29422 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 349 29672 target.c:1157 target_read_u16(): address: 0x10000000, value: 0x001f
Debug: 350 29672 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000002, size: 0x00000002, count: 0x00000001
Debug: 351 29922 target.c:1157 target_read_u16(): address: 0x10000002, value: 0x02de
Debug: 352 29922 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 353 30109 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 354 30172 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 355 30359 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 356 30422 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 357 30609 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 358 30672 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000020, size: 0x00000002, count: 0x00000001
Debug: 359 30922 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000022, size: 0x00000002, count: 0x00000001
Debug: 360 31172 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000024, size: 0x00000002, count: 0x00000001
Debug: 361 31422 cfi.c:1933 cfi_probe(): CFI qry returned: 0x51 0x52 0x59
Debug: 362 31422 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000026, size: 0x00000002, count: 0x00000002
Debug: 363 31875 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000002a, size: 0x00000002, count: 0x00000002
Debug: 364 32312 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000002e, size: 0x00000002, count: 0x00000002
Debug: 365 32718 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000032, size: 0x00000002, count: 0x00000002
Debug: 366 33125 cfi.c:1950 cfi_probe(): qry: 'QRY', pri_id: 0x0003, pri_addr: 0x0041, alt_id: 0x0000, alt_addr: 0x0000
Debug: 367 33125 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000036, size: 0x00000002, count: 0x00000001
Debug: 368 33375 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000038, size: 0x00000002, count: 0x00000001
Debug: 369 33625 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000003a, size: 0x00000002, count: 0x00000001
Debug: 370 33875 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000003c, size: 0x00000002, count: 0x00000001
Debug: 371 34125 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000003e, size: 0x00000002, count: 0x00000001
Debug: 372 34375 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000040, size: 0x00000002, count: 0x00000001
Debug: 373 34625 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000042, size: 0x00000002, count: 0x00000001
Debug: 374 34875 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000044, size: 0x00000002, count: 0x00000001
Debug: 375 35125 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000046, size: 0x00000002, count: 0x00000001
Debug: 376 35375 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000048, size: 0x00000002, count: 0x00000001
Debug: 377 35625 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000004a, size: 0x00000002, count: 0x00000001
Debug: 378 35875 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000004c, size: 0x00000002, count: 0x00000001
Debug: 379 36125 cfi.c:1969 cfi_probe(): Vcc min: 2.7, Vcc max: 3.6, Vpp min: 9.0, Vpp max: a.0
Debug: 380 36125 cfi.c:1971 cfi_probe(): typ. word write timeout: 16, typ. buf write timeout: 4, typ. block erase timeout: 512,
typ. chip erase timeout: 1
Debug: 381 36125 cfi.c:1975 cfi_probe(): max. word write timeout: 256, max. buf write timeout: 64, max. block erase timeout: 409
6, max. chip erase timeout: 1
Debug: 382 36125 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000004e, size: 0x00000002, count: 0x00000001
Debug: 383 36375 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000050, size: 0x00000002, count: 0x00000002
Debug: 384 36812 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000054, size: 0x00000002, count: 0x00000002
Debug: 385 37218 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000058, size: 0x00000002, count: 0x00000001
Debug: 386 37422 cfi.c:1982 cfi_probe(): size: 0x800000, interface desc: 1, max buffer write size: 4
Debug: 387 37422 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000005a, size: 0x00000002, count: 0x00000004
Debug: 388 38265 cfi.c:1995 cfi_probe(): erase region[0]: 8 blocks of size 0x2000
Debug: 389 38265 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000062, size: 0x00000002, count: 0x00000004
Debug: 390 39078 cfi.c:1995 cfi_probe(): erase region[1]: 127 blocks of size 0x10000
Debug: 391 39078 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000082, size: 0x00000002, count: 0x00000001
Debug: 392 39328 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000084, size: 0x00000002, count: 0x00000001
Debug: 393 39578 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000086, size: 0x00000002, count: 0x00000001
Debug: 394 39828 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000088, size: 0x00000002, count: 0x00000001
Debug: 395 40078 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000008a, size: 0x00000002, count: 0x00000001
Debug: 396 40328 cfi.c:364 cfi_read_intel_pri_ext(): pri: 'PRI', version: 1.0
Debug: 397 40328 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000008c, size: 0x00000002, count: 0x00000004
Debug: 398 41125 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000094, size: 0x00000002, count: 0x00000001
Debug: 399 41375 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000096, size: 0x00000002, count: 0x00000002
Debug: 400 41828 cfi.c:370 cfi_read_intel_pri_ext(): feature_support: 0x186, suspend_cmd_support: 0x80, blk_status_reg_mask: 0x3
03
Debug: 401 41828 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000009a, size: 0x00000002, count: 0x00000001
Debug: 402 42078 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000009c, size: 0x00000002, count: 0x00000001
Debug: 403 42328 cfi.c:377 cfi_read_intel_pri_ext(): Vcc opt: f.f, Vpp opt: f.f
Debug: 404 42328 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x1000009e, size: 0x00000002, count: 0x00000001
Warning: 405 42578 cfi.c:382 cfi_read_intel_pri_ext(): expected one protection register field, but found 255
Debug: 406 42578 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x100000a0, size: 0x00000002, count: 0x00000002
Debug: 407 43015 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x100000a4, size: 0x00000002, count: 0x00000001
Debug: 408 43281 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x100000a6, size: 0x00000002, count: 0x00000001
Debug: 409 43531 cfi.c:389 cfi_read_intel_pri_ext(): protection_fields: 255, prot_reg_addr: 0xffff, factory pre-programmed: -214
7483648, user programmable: -2147483648
Debug: 410 43531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 411 43718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 412 43781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 413 43968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 414 44031 command.c:383 command_run_line(): sleep 2
Debug: 415 44047 command.c:383 command_run_line(): mwb 0x10000000 0x60 1
Debug: 416 44047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 417 44218 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 418 44281 command.c:383 command_run_line(): mwb 0x10000000 0xD0 1
Debug: 419 44281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 420 44468 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 421 44531 command.c:383 command_run_line(): sleep 1
Debug: 422 44547 command.c:383 command_run_line(): mwb 0x10002000 0x60 1
Debug: 423 44547 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 424 44718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 425 44781 command.c:383 command_run_line(): mwb 0x10002000 0xD0 1
Debug: 426 44781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 427 44968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 428 45031 command.c:383 command_run_line(): sleep 1
Debug: 429 45047 command.c:383 command_run_line(): mwb 0x10004000 0x60 1
Debug: 430 45047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 431 45218 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 432 45281 command.c:383 command_run_line(): mwb 0x10004000 0xD0 1
Debug: 433 45281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 434 45468 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 435 45531 command.c:383 command_run_line(): sleep 1
Debug: 436 45547 command.c:383 command_run_line(): mwb 0x10006000 0x60 1
Debug: 437 45547 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 438 45718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 439 45781 command.c:383 command_run_line(): mwb 0x10006000 0xD0 1
Debug: 440 45781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 441 45968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 442 46031 command.c:383 command_run_line(): sleep 1
Debug: 443 46047 command.c:383 command_run_line(): mwb 0x10008000 0x60 1
Debug: 444 46047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 445 46218 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 446 46281 command.c:383 command_run_line(): mwb 0x10008000 0xD0 1
Debug: 447 46281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 448 46468 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 449 46531 command.c:383 command_run_line(): sleep 1
Debug: 450 46547 command.c:383 command_run_line(): mwb 0x1000A000 0x60 1
Debug: 451 46547 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 452 46718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 453 46781 command.c:383 command_run_line(): mwb 0x1000A000 0xD0 1
Debug: 454 46781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 455 46968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 456 47031 command.c:383 command_run_line(): sleep 1
Debug: 457 47047 command.c:383 command_run_line(): mwb 0x1000C000 0x60 1
Debug: 458 47047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 459 47218 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 460 47281 command.c:383 command_run_line(): mwb 0x1000C000 0xD0 1
Debug: 461 47281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 462 47468 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 463 47531 command.c:383 command_run_line(): sleep 1
Debug: 464 47547 command.c:383 command_run_line(): mwb 0x1000E000 0x60 1
Debug: 465 47547 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 466 47718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 467 47781 command.c:383 command_run_line(): mwb 0x1000E000 0xD0 1
Debug: 468 47781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 469 47968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 470 48031 command.c:383 command_run_line(): sleep 1
Debug: 471 48047 command.c:383 command_run_line(): mwb 0x10010000 0x60 1
Debug: 472 48047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 473 48218 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 474 48281 command.c:383 command_run_line(): mwb 0x10010000 0xD0 1
Debug: 475 48281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 476 48468 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 477 48531 command.c:383 command_run_line(): sleep 1
Debug: 478 48547 command.c:383 command_run_line(): mwb 0x10020000 0x60 1
Debug: 479 48547 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 480 48718 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 481 48781 command.c:383 command_run_line(): mwb 0x10020000 0xD0 1
Debug: 482 48781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 483 48968 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 484 49031 command.c:383 command_run_line(): sleep 1
Debug: 485 49047 command.c:383 command_run_line(): flash erase_sector 0 0 9
Debug: 486 49047 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 487 49234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 488 49281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 489 49484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 490 49531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 491 49734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 492 49781 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 493 50031 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 494 50031 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 495 50234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 496 50281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 497 50484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 498 50531 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 499 50781 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 500 50781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 501 50984 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 502 51031 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 503 51234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 504 51281 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 505 51531 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 506 51531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 507 51734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 508 51781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 509 51984 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 510 52031 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 511 52281 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 512 52281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 513 52484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 514 52531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 515 52734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 516 52781 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 517 53031 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 518 53031 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 519 53234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 520 53281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 521 53484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 522 53531 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 523 53781 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 524 53781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 525 53984 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 526 54031 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 527 54234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 528 54281 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 529 54531 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 530 54531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 531 54734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 532 54781 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 533 54984 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 534 55031 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 535 55281 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 536 55281 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 537 55484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 538 55531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 539 55734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 540 55781 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 541 55984 cfi.c:269 cfi_intel_wait_status_busy(): status: 0x0
Debug: 542 56000 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 543 56234 cfi.c:269 cfi_intel_wait_status_busy(): status: 0x0
Debug: 544 56250 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 545 56484 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 546 56484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 547 56687 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 548 56734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 549 56937 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 550 56984 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 551 57234 cfi.c:269 cfi_intel_wait_status_busy(): status: 0x0
Debug: 552 57250 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 553 57484 cfi.c:269 cfi_intel_wait_status_busy(): status: 0x0
Debug: 554 57500 arm7_9_common.c:1772 arm7_9_read_memory(): address: 0x10000000, size: 0x00000002, count: 0x00000001
Debug: 555 57734 cfi.c:276 cfi_intel_wait_status_busy(): status: 0x80
Debug: 556 57734 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 557 57937 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 558 57984 command.c:383 command_run_line(): sleep 10
Debug: 559 58000 command.c:383 command_run_line(): flash write_image 0x10000000.bin 0x10000000 bin
Debug: 560 58000 configuration.c:87 open_file_from_path(): opened 0x10000000.bin
Debug: 561 58000 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 562 58187 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 563 58234 target.c:819 target_alloc_working_area(): allocating new working area
Debug: 564 58234 target.c:958 target_write_buffer(): writing buffer of 56 byte at 0x00200000
Debug: 565 58234 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 566 58437 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 567 58484 target.c:819 target_alloc_working_area(): allocating new working area
Info: 568 58484 cfi.c:1134 cfi_intel_write_block(): Using target buffer at 0x00200038 and of size 0x8000
Debug: 569 58484 target.c:958 target_write_buffer(): writing buffer of 1200 byte at 0x00200038
Debug: 570 58484 target.c:819 target_alloc_working_area(): allocating new working area
Debug: 571 58484 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 572 58687 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 573 58734 arm7_9_common.c:1422 arm7_9_resume(): -
Debug: 574 58734 arm7_9_common.c:1226 arm7_9_restore_context():
AHHHHHHH just lost the second half of my post ![]()
