hi
I have got Insight / GNUARM / OpenOCD / Amontec JTAGKey working on Windows for use in flashing and debugging the Philips LPC2106 and it works well.
I am now trying to migrate it all to Linux but am stuck at openocd / Amontec JTAGKey operation.
I am using openocd-r119 from the svn database, and the latest amontec jtagkey library file. All compiled and installed without error.
When I run the openocd program to flash the ARM device, the program works intermittently. Most of the time, it locks up during the flash erase or flash write operations, and several seconds later it may or may not continue.
I thought it might be a JTAG speed setting but I changed that and no improvement.
I also ran the openocd program through ddd debugger and it showed that during the hangup it was in an ioctl routine inside the Amontec shared library [routine was usb_bulk_write] called from openocd ftd2xx.c/FT_Write routine.
Any ideas of where this breakdown might be occurring.
Kent.
Here are my config files and transcripts:
OpenOCD configuration
Flash LPC2106 memory using openocd
and a FTDI FT2232-based JTAG-interface
created by Martin Thomas
based on information from Dominic Rath
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc “Amontec JTAGkey A”
ft2232_layout jtagkey
ft2232_vid_pid 0x0403 0xcff8
jtag_speed 3
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_init 0 arm7tdmi-s_r4
run_and_halt_time 0 30
flash-options LPC2106
target_script 0 reset openocd_lpc2106_flash.script
working_area 0 0x40000000 0x4000 nobackup
LPC2106 @ 14.74MHz / 0x7D000 from 500*1024 (not 512!)
flash bank lpc2000 0x0 0x40000 0 0 lpc2000_v1 0 14740 calc_checksum
For more information about the configuration files, take a look at:
http://openfacts.berlios.de/index-en.ph … p+Debugger
OpenOCDScript file for flashing device
The following command wills be executed on
reset (because of run_and_init in the config-file)
- wait for target halt
- erase memory
- flash content of file main.bin into target-memory
- shutdown openocd
http://www.siwawi.arubi.uni-kl.de/avr_p … m_projects
arm7_9 dcc_downloads enable
wait_halt
sleep 10
poll
flash probe 0
flash erase 0 0 0
flash write 0 main.bin 0x0
reset run
sleep 10
shutdown
Output from OpenOCD without debug
[Note: In this example, the openocd locks up for 2 seconds near the start and continues, then locks up for 17 seconds during the flash write before continuing - you can see that by the “inter” values in the print statements]
[Note also that although it hung up twice, both times it resumed and completed successfully - many other times I have tried, the prgram has not returned from the hang up]
Info: openocd.c:84 main(): Open On-Chip Debugger (2006-11-22 14:00 CEST)
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.981, inter2: 0.981 end: 0.3009
Warning: arm7_9_common.c:683 arm7_9_assert_reset(): srst resets test logic, too
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2089, inter2: 0.2090 end: 0.3139
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1681, inter2: 0.1681 end: 0.2726
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.826, inter2: 0.826 end: 0.3861
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2081, inter2: 0.2081 end: 0.5115
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1156, inter2: 0.1156 end: 0.3184
Info: target.c:219 target_init_handler(): executing reset script ‘openocd_lpc2106_flash.script’
Info: configuration.c:50 configuration_output_handler(): dcc downloads are enabled
Info: configuration.c:50 configuration_output_handler(): waiting for target halted…
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1154, inter2: 0.1155 end: 0.4272
Info: configuration.c:50 configuration_output_handler(): target halted
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1102, inter2: 0.1102 end: 0.2137
Info: configuration.c:50 configuration_output_handler(): target state: halted
Info: configuration.c:50 configuration_output_handler(): target halted in Thumb state due to debug request, current mode: Supervisor
Info: configuration.c:50 configuration_output_handler(): cpsr: 0x800000f3 pc: 0x7fffe250
Info: configuration.c:50 configuration_output_handler(): flash ‘lpc2000’ found at 0x00000000
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1834, inter2: 0.1835 end: 0.4868
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1127, inter2: 0.1127 end: 0.3158
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 2.970731, inter2: 2.970731 end: 2.971775
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1865, inter2: 0.1865 end: 0.4940
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1928, inter2: 0.1928 end: 0.4956
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1133, inter2: 0.1133 end: 0.3213
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1084, inter2: 0.1085 end: 0.3113
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2823, inter2: 0.2823 end: 0.5854
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1003, inter2: 0.1003 end: 0.2161
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.138, inter2: 0.139 end: 0.2169
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2031, inter2: 0.2031 end: 0.4067
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1917, inter2: 0.1917 end: 0.3948
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.985, inter2: 0.985 end: 0.2194
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1065, inter2: 0.1066 end: 0.3096
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1079, inter2: 0.1080 end: 0.3111
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2831, inter2: 0.2832 end: 0.5862
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1101, inter2: 0.1101 end: 0.3132
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1988, inter2: 0.1988 end: 0.5020
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1079, inter2: 0.1079 end: 0.3108
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1115, inter2: 0.1116 end: 0.4173
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.3541, inter2: 0.3542 end: 0.6573
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1096, inter2: 0.1096 end: 0.3125
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2921, inter2: 0.2922 end: 0.3955
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2893, inter2: 0.2893 end: 0.3927
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2910, inter2: 0.2910 end: 0.3953
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2912, inter2: 0.2913 end: 0.3946
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2914, inter2: 0.2914 end: 0.3947
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2917, inter2: 0.2917 end: 0.3949
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2915, inter2: 0.2916 end: 0.3948
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2389, inter2: 0.2389 end: 0.3433
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2910, inter2: 0.2910 end: 0.3944
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2910, inter2: 0.2911 end: 0.3943
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2909, inter2: 0.2909 end: 0.3942
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2901, inter2: 0.2901 end: 0.3934
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2857, inter2: 0.2857 end: 0.3891
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2885, inter2: 0.2885 end: 0.3929
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2798, inter2: 0.2798 end: 0.3836
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2904, inter2: 0.2904 end: 0.3938
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2903, inter2: 0.2904 end: 0.3937
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2893, inter2: 0.2893 end: 0.3926
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2454, inter2: 0.2455 end: 0.3497
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2897, inter2: 0.2898 end: 0.3933
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.969, inter2: 0.969 end: 0.4004
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2878, inter2: 0.2878 end: 0.5957
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1955, inter2: 0.1955 end: 0.3988
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1044, inter2: 0.1044 end: 0.4076
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1959, inter2: 0.1959 end: 0.4990
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1800, inter2: 0.1801 end: 0.4830
Info: configuration.c:50 configuration_output_handler(): erased sectors 0 through 0 on flash bank 0 in 3s 525832us
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2806, inter2: 0.2807 end: 0.5842
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1947, inter2: 0.1947 end: 0.3976
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1785, inter2: 0.1786 end: 0.4814
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1982, inter2: 0.1982 end: 0.4009
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2007, inter2: 0.2007 end: 0.5035
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.3436, inter2: 0.3436 end: 0.6466
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1965, inter2: 0.1966 end: 0.3995
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.948, inter2: 0.948 end: 0.3990
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2707, inter2: 0.2707 end: 0.5737
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1939, inter2: 0.1939 end: 0.3967
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2019, inter2: 0.2019 end: 0.4052
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1883, inter2: 0.1883 end: 0.4911
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1926, inter2: 0.1927 end: 0.4953
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2730, inter2: 0.2730 end: 0.5765
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1907, inter2: 0.1907 end: 0.3935
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.3515, inter2: 0.3516 end: 0.6547
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.6789, inter2: 0.6789 end: 0.9822
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1793, inter2: 0.1794 end: 0.4826
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1878, inter2: 0.1878 end: 0.3906
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 17.371774, inter2: 17.371774 end: 17.372817
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.811, inter2: 0.811 end: 0.2850
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1708, inter2: 0.1709 end: 0.2743
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.879, inter2: 0.879 end: 0.2882
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.851, inter2: 0.851 end: 0.1895
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2526, inter2: 0.2526 end: 0.4556
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.927, inter2: 0.928 end: 0.1978
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2937, inter2: 0.2938 end: 0.3972
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.962, inter2: 0.963 end: 0.2002
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1742, inter2: 0.1742 end: 0.3775
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.826, inter2: 0.826 end: 0.1883
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.879, inter2: 0.880 end: 0.1922
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.798, inter2: 0.798 end: 0.1915
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.730, inter2: 0.731 end: 0.1772
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1662, inter2: 0.1663 end: 0.3693
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.843, inter2: 0.843 end: 0.1881
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1711, inter2: 0.1712 end: 0.2749
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.839, inter2: 0.839 end: 0.2876
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.847, inter2: 0.847 end: 0.1913
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.3530, inter2: 0.3531 end: 0.5416
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.899, inter2: 0.900 end: 0.2899
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.962, inter2: 0.963 end: 0.2997
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1746, inter2: 0.1747 end: 0.3810
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.796, inter2: 0.796 end: 0.1931
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.800, inter2: 0.800 end: 0.1970
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.669, inter2: 0.669 end: 0.1798
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.725, inter2: 0.725 end: 0.1955
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.3186, inter2: 0.3187 end: 0.5216
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.6766, inter2: 0.6766 end: 0.9800
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1790, inter2: 0.1790 end: 0.3881
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.774, inter2: 0.775 end: 0.2208
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1278, inter2: 0.1278 end: 0.3309
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.845, inter2: 0.845 end: 0.2137
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1461, inter2: 0.1461 end: 0.3494
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.834, inter2: 0.834 end: 0.2191
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.532, inter2: 0.532 end: 0.3564
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2533, inter2: 0.2534 end: 0.5562
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.891, inter2: 0.891 end: 0.3930
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1928, inter2: 0.1928 end: 0.2965
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1023, inter2: 0.1024 end: 0.2001
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1738, inter2: 0.1738 end: 0.3813
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.783, inter2: 0.784 end: 0.1850
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.867, inter2: 0.867 end: 0.1930
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.773, inter2: 0.773 end: 0.1888
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.753, inter2: 0.753 end: 0.1844
Info: configuration.c:50 configuration_output_handler(): wrote file main.bin to flash bank 0 at offset 0x00000000 in 17s 671299us
Output from OpenOCD with debug
[note this is a different execution of the openOCD in which it locks up and doesn’t continue]
Debug: jtag.c:1217 jtag_init():
Debug: ft2232.c:1244 ft2232_init(): ‘ft2232’ interface using FTD2XX with ‘jtagkey’ layout
[New Thread 32769 (LWP 5849)]
[New Thread 16386 (LWP 5850)]
Debug: ft2232.c:1330 ft2232_init(): current latency timer: 2
Debug: ft2232.c:1502 jtagkey_init(): 80 08 1b
Debug: ft2232.c:1560 jtagkey_init(): 82 09 0f
Debug: ft2232.c:242 ft2232_speed(): 86 03 00
Debug: jtag.c:254 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1103 jtag_reset_callback():
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 3):
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 4b 06 7f
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 9):
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 4b 06 1b 3b 04 3f 6b 06 ff
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1998, inter2: 0.1998 end: 0.5046
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 2 bytes
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 88 33
Debug: openocd.c:102 main(): jtag init complete
Debug: arm7_9_common.c:656 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:254 jtag_call_event_callbacks(): jtag event: 0
Debug: ft2232.c:940 jtagkey_reset(): trst: 1, srst: 1, high_output: 0x00, high_direction: 0x0f
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 82 00 0f
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 0):
Debug: arm7_9_common.c:722 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:254 jtag_call_event_callbacks(): jtag event: 2
Debug: ft2232.c:940 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 82 09 0f
Debug: openocd.c:106 main(): target init complete
Debug: openocd.c:110 main(): flash init complete
Debug: openocd.c:114 main(): pld init complete
Debug: gdb_server.c:1347 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:157 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:254 jtag_call_event_callbacks(): jtag event: 3
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 59):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 1b 3b 02 12 6b 06 31 4b 06 25 1b 02 12 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 31 4b 06 2b 3b 02 1c 6b 06 b1 4b 06 25 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 00 00 00 00 1b 04 01 4b 06 31 4b 06 25 39 03
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 00 00 00 00 00 3b 04 04 6b 06 31
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1594, inter2: 0.1595 end: 0.4820
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 10 bytes
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 26 00 20 00 04 00 00 00 08 00
Debug: arm7_9_common.c:838 arm7_9_halt(): target->state: running
Debug: embeddedice.c:253 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:253 embeddedice_write_reg(): 13: 0x000000f7
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 96):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 ff ff ff ff 1b 04 29 4b 06 b1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 ff ff ff ff 1b 04 2b 4b 06 b1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 00 01 00 00 1b 04 2c 4b 06 b1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 f7 00 00 00 1b 04 2d 4b 06 b1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 04 00 00 00 1b 04 01 4b 06 31
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 39 03 00 04 00 00 00 3b 04 04 6b 06 31
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.8570, inter2: 0.8570 end: 0.11620
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 6 bytes
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 09 00 00 00 08 00
Debug: arm7_9_common.c:620 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000000
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 32):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 05 00 00 00 1b 04 20 4b 06 b1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 00 00 00 00 1b 04 2c 4b 06 b1
Debug: arm7_9_common.c:944 arm7_9_debug_entry(): target entered debug from ARM state
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 415):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 2b 3b 02 f2 6b 06 17 4b 06 20 1b 02 f1 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 1e 3b 02 fc 6b 06 97 4b 06 20 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 2e 02 fe ff 4b 06 81 4b 06 30 4b 06 05 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 19 03 00 0e 0b 02 20 4b 06 01 4b 06 30 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 05 4b 06 20 19 03 00 0e 0b 02 20 4b 06 01 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 30 4b 06 05 4b 06 20 28 03 00 6b 06 01 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 05 4b 06 20 28 03 00 6b 06 01 4b 06 30 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 05 4b 06 20 28 03 00 6b 06 01 4b 06 30 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 05 4b 06 20 28 03 00 6b 06 01 4b 06 30 4b 06 05
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 28 03 00 6b 06 01 4b 06 30 4b 06 05 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 20 28 03 00 6b 06 01 4b 06 30 4b 06 05 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 28 03 00 6b 06 01 4b 06 30 4b 06 05 4b 06 20
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 28 03 00 6b 06 01 4b 06 30 4b 06 05 4b 06 20 28
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 6b 06 01 4b 06 30 4b 06 05 4b 06 20 28 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 6b 06 01 4b 06 30 4b 06 05 4b 06 20 28 03 00
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 6b 06 01 4b 06 30 4b 06 05 4b 06 20 28 03 00 6b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 20 28 03 00 6b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 01 4b 06 30 4b 06 05 4b 06 20 28 03 00 6b 06 01
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 30 4b 06 05 4b 06 20 28 03 00 6b 06 01 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 30 4b 06 05 4b 06 20 28 03 00 6b 06 01 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 30 4b 06 05 4b 06 20 19 03 00 0e e1 01 00 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 4e e3 01
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 0e 0b 02 20 4b 06 01 4b 06 30 4b 06 05 4b 06 20
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 19 03 00 0e 0b 02 20 4b 06 01 4b 06 30 4b 06 05
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 4b 06 20 28 03 00 6b 06 01 4b 06 30 4b 06 05
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.9945, inter2: 0.9946 end: 0.16168
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 89 bytes
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 00 20 0c 0e 80 02 40 00 0e 80 02 20 00 00 e0
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): d6 bd 01 00 00 00 02 00 00 00 00 00 00 0e f0 07
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 04 00 04 00 00 29 00 00 00 00 00 00 04 00 00 96
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 01 fe ff ff ff 03 fe ff ff ff 03 fe ff ff ff 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 0e 80 02 60 00 04 00 fe 26 00 00 e0 05 00 00 00
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 00 80 14 00 08 00 00 f6 03
Debug: arm7_9_common.c:976 arm7_9_debug_entry(): target entered debug state in System mode
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r0: 0xe0028004
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r1: 0xe0028008
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r2: 0x000ed77a
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0x00000080
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r4: 0x00000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r5: 0xe01fc040
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r6: 0x40000128
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r7: 0x00000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r8: 0x400000d2
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r9: 0xffffffff
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r10: 0xffffffff
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r11: 0xffffffff
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r12: 0xe002800c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r13: 0x4000fec8
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r14: 0x000f4000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x00000238
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x238
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 91):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 19 03 00 0e e1 01 00 4b 06 01 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 05 4b 06 20 19 03 00 4e e3 01 00 4b 06 01
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 30 4b 06 05 4b 06 20 19 03 00 0e 0b 02 20
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 0e
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 0b 02 20 4b 06 01 4b 06 30 4b 06 05 4b 06 20 28
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 03 00 6b 06 01 4b 06 30 4b 06 05
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.657, inter2: 0.657 end: 0.1681
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 5 bytes
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 08 00 00 f6 03
Debug: target.c:442 target_call_event_callbacks(): target event 0
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 1e 3b 02 02 6b 06 31 4b 06 25 1b 02 02 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 31 4b 06 2b 3b 02 0c 6b 06 b1 4b 06 25 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 09 00 00 00 1b 04 01 4b 06 31 4b 06 25 39 03
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 00 09 00 00 00 3b 04 04 6b 06 31
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.774, inter2: 0.775 end: 0.1799
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 20 00 20 00 09 00 00 00 08 7c
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 19 03 00 09 00 00 00 1b 04 41 4b 06 31
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 25 39 03 00 09 00 00 00 3b 04 44 6b 06 31
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.11554, inter2: 0.11555 end: 0.14598
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 09 00 00 00 08 7c
Info: configuration.c:50 configuration_output_handler(): target halted in ARM state due to debug request, current mode: System
Info: configuration.c:50 configuration_output_handler(): cpsr: 0x200000df pc: 0x00000238
Debug: target.c:522 target_alloc_working_area(): allocating new working area
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0x40000000, size: 0x00000004, count: 0x00000002
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000004
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 431):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 2e 12 00 00 4b 06 81 4b 06 30 4b 06 05 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 30 4b 06 05 4b 06 20 19 03 00 04 00 00 00 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 0e 0b 02
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 4b 06 01 4b 06 30 4b 06 05 4b 06 1e 3b 02 f2
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 6b 06 31 4b 06 25 1b 02 f2 4b 06 31 4b 06 2b 3b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 02 fc 6b 06 b1 4b 06 25 19 03 00 04 00 00 00 1b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 04 20 4b 06 b1 4b 06 2b 3b 02 f2 6b 06 17 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 1b 02 f1 4b 06 01 4b 06 1e 3b 02 fc 6b 06 97
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 19 03 00 2e 12 00 c0 4b 06 01 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 05 4b 06 20 19 03 00 0e 0b 02 20 4b 06 01
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): e9 ff 71 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 ae fe ff ff 4b 06 01 4b 06 30 4b 06 05 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 20 19 03 00 0e 0b 02 20 4b 06 01 4b 06 30 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 05 4b 06 20 19 03 00 0e 0b 02 20 4b 06 01 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 30 4b 06 05 4b 06 20 19 03 00 0f 0b 02 20 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 2e 0a
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 c0 4b 06 01 4b 06 30 4b 06 05 4b 06 1e 3b 02
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): f4 6b 06 31 4b 06 2b 3b 02 f2 6b 06 31 4b 06 25
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 1b 02 f2 4b 06 31 4b 06 2b 3b 02 fc 6b 06 b1 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 25 19 03 00 09 00 00 00 1b 04 01 4b 06 31 4b
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 06 25 39 03 00 09 00 00 00 3b 04 04 6b 06 31
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.1862, inter2: 0.1863 end: 0.2907
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 24 bytes
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 2f 00 20 0c 21 00 20 00 20 00 20 0c 21 00 20 00
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 20 00 09 00 00 00 08 7c
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 134):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 2b 3b 02 e2 6b 06 17 4b 06 20 1b 02 e1 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 1e 3b 02 ec 6b 06 97 4b 06 20 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 0e e1 01 00 4b 06 01 4b 06 30 4b 06 05 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 19 03 00 4e e3 01 00 4b 06 01 4b 06 30 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 30 4b 06 05 4b 06 20 19 03 00 0e 0b 02 20 4b 06
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 4b 06 30 4b 06 05
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2738, inter2: 0.2739 end: 0.3771
Debug: ft2232.c:391 ft2232_send_and_recv(): read buffer (0 retries): 9 bytes
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 2f 0c 21 cc 08 00 00 f6 03
Debug: arm7tdmi.c:506 arm7tdmi_write_xpsr_im8(): xpsr_im: d3, rot: 0, spsr: 0
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 148):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 19 03 00 8e 09 1f 96 4b 06 81 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 0b 02 20 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 2e 02 08 00 4b 06 01 4b 06 30 4b 06 05 4b
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 30 4b 06 05
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2786, inter2: 0.2787 end: 0.3807
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 04 00 fe 66 00
Debug: arm7tdmi.c:506 arm7tdmi_write_xpsr_im8(): xpsr_im: df, rot: 0, spsr: 0
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 224):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 19 03 00 8e 09 1f f6 4b 06 81 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 8e 09 1f 96 4b 06 81 4b 06 30 4b 06 05 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 30 4b 06 05 4b 06 20 19 03 00 0e 0b 02 20 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 2e 02
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 04 00 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 0e 0b 02 20 4b 06 01 4b 06 30 4b 06 05 4b 06
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.938, inter2: 0.938 end: 0.1979
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): fc ff 8f e6 03
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 243):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 0e e1
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 01 00 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 4e e3 01 00 4b 06 01 4b 06 30 4b 06 05 4b 06
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 4b 06 05
Info: ft2232.c:376 ft2232_send_and_recv(): inter: 0.2713, inter2: 0.2713 end: 0.3739
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 08 00 00 96 03
Debug: target.c:623 target_write_buffer(): writing buffer of 24 byte at 0x40000008
Debug: arm7_9_common.c:1822 arm7_9_write_memory(): address: 0x40000008, size: 0x00000004, count: 0x00000006
Debug: ft2232.c:336 ft2232_send_and_recv(): write buffer (size 556):
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 2e 12 00 00 4b 06 81 4b 06 30 4b 06 05 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 30 4b 06 05 4b 06 20 19 03 00 04 00 00 20 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 0e 0b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 02 20 4b 06 01 4b 06 30 4b 06 05 4b 06 1e 3b 02
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 72 6b 06 31 4b 06 25 1b 02 72 4b 06 31 4b 06 2b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 3b 02 7c 6b 06 b1 4b 06 25 19 03 00 04 00 00 00
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 1b 04 20 4b 06 b1 4b 06 2b 3b 02 72 6b 06 17 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 20 1b 02 71 4b 06 01 4b 06 1e 3b 02 7c 6b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 97 4b 06 20 19 03 00 2e 12 00 fc 4b 06 01 4b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 20 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 00 00 00 98 4b 06 01 4b 06 30 4b 06 05 4b 06 20
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 19 03 00 00 00 00 00 4b 06 01 4b 06 30 4b 06 05
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 20 19 03 00 00 00 00 00 4b 06 01 4b 06 30
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 05 4b 06 20 19 03 00 00 00 38 53 4b 06 01
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 30 4b 06 05 4b 06 20 19 03 00 04 50 fb 5f
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19 03 00 fa
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): ff 8f 38 4b 06 01 4b 06 30 4b 06 05 4b 06 20 19
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 0e 0b 02 20 4b 06 01 4b 06 30 4b 06 05 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 05 4b 06 20 19 03 00 0f 0b 02 20 4b 06 01 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 30 4b 06 05 4b 06 20 19 03 00 2e 0a 00 fc 4b
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 06 01 4b 06 30 4b 06 05 4b 06 1e 3b 02 74 6b 06
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 31 4b 06 2b 3b 02 72 6b 06 31 4b 06 25 1b 02 72
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 4b 06 31 4b 06 2b 3b 02 7c 6b 06 b1 4b 06 25 19
Debug: ft2232.c:311 ft2232_debug_dump_buffer(): 03 00 09 00 00 00 1b 04 01 4b 06 31 4b 06 25 39
Debug: ft2232.c:317 ft2232_debug_dump_buffer(): 03 00 09 00 00 00 3b 04 04 6b 06 31
