GDB + Eclipse + ARM-USB-OCD + Interrupts = Error
I have troubles at debugging an interrupt program :slight_smile:
I’m running a simple, small test program, which is waiting in a while(1). A timer, initialized bevore, calls it’s interrupt service routine and increments a counter. If I step through the program using F6 (Single Stepping) the debugger enters enableIRQ(); and does not come back.
Can someone help me please?!
Kind regards Michael
void DefaultISR (void) __attribute__ ((interrupt));
void Timer0ISR (void) __attribute__ ((interrupt));
unsigned int volatile gTimerTick;
void DefaultISR (void){
  while (1){} // We should never get here, if we do it is an error
void Timer0ISR(void) {
  gTimerTick++;
  T0IR = 1; // Clear interrupt flag
  VICVectAddr = 0xFFFFFFFF; // Acknowledge Interrupt
int main(void){
  VICIntEnClr = 0xFFFFFFFFL; // Disable all Ints
  VICIntSelect = 0x00000000L;
  VICDefVectAddr = (unsigned long) DefaultISR; // set interrupt vector
  T0MR0 = 5999; // 100 microseconds = 6.000-1 counts
  T0MCR = 3; // Interrupt and Reset on MR0
  T0TCR = 1;  // Timer0 Enable
  VICVectAddr3 = (unsigned long) Timer0ISR; // set interrupt vector
  VICVectCntl3 = 0x20 | 4;  // use it for Timer 0 Interrupt
  VICIntEnable = 0x00000010;  // enable Timer0 Interrupt
  VPBDIV = 1;
  enableIRQ();
  while(1){}
I’d like to attach a log but attachments aren’t accepted…
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Z0,40000240,4’
Debug: gdb_server.c:1095 gdb_breakpoint_watchpoint_packet():
Debug: breakpoints.c:93 breakpoint_add(): added software breakpoint at 0x40000240 of length 0x00000004
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$OK#9a’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$Z0,40000138,4#a6’
Debug: gdb_server.c:239 gdb_get_packet(): character: β€˜$’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Z0,40000138,4’
Debug: breakpoints.c:93 breakpoint_add(): added software breakpoint at 0x40000138 of length 0x00000004
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$Z0,40000124,4#a1’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Z0,40000124,4’
Debug: breakpoints.c:93 breakpoint_add(): added software breakpoint at 0x40000124 of length 0x00000004
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$Z0,4000023c,4#d2’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Z0,4000023c,4’
Debug: breakpoints.c:93 breakpoint_add(): added software breakpoint at 0x4000023c of length 0x00000004
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$Z0,4000018c,4#d6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Z0,4000018c,4’
Debug: breakpoints.c:93 breakpoint_add(): added software breakpoint at 0x4000018c of length 0x00000004
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$s#73’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜s’
Debug: gdb_server.c:1042 gdb_step_continue_packet():
Debug: gdb_server.c:1061 gdb_step_continue_packet(): step
Debug: arm7_9_common.c:1127 arm7_9_restore_context():
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining User mode
Debug: arm7_9_common.c:1157 arm7_9_restore_context(): examining dirty reg: r0
Debug: arm7_9_common.c:1157 arm7_9_restore_context(): examining dirty reg: r1
Debug: arm7_9_common.c:1157 arm7_9_restore_context(): examining dirty reg: pc
Debug: arm7_9_common.c:1206 arm7_9_restore_context(): writing register 0 of mode User with value 0x00000000
Debug: arm7_9_common.c:1206 arm7_9_restore_context(): writing register 1 of mode User with value 0x00000000
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining FIQ mode
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining IRQ mode
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining Supervisor mode
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining Abort mode
Debug: arm7_9_common.c:1143 arm7_9_restore_context(): examining Undefined mode
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x40000228
Debug: embeddedice.c:299 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:299 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:299 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:299 embeddedice_write_reg(): 13: 0x00000077
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x40000228
Debug: embeddedice.c:299 embeddedice_write_reg(): 17: 0x00000000
Debug: embeddedice.c:299 embeddedice_write_reg(): 19: 0xffffffff
Debug: embeddedice.c:299 embeddedice_write_reg(): 20: 0x00000000
Debug: embeddedice.c:299 embeddedice_write_reg(): 21: 0x000000f7
Debug: target.c:444 target_call_event_callbacks(): target event 1
Debug: embeddedice.c:203 embeddedice_read_reg_w_check(): 1
Debug: embeddedice.c:299 embeddedice_write_reg(): 11: 0x00000000
Debug: embeddedice.c:299 embeddedice_write_reg(): 13: 0x000000f7
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x4000018c
Debug: embeddedice.c:299 embeddedice_write_reg(): 17: 0x00000003
Debug: embeddedice.c:299 embeddedice_write_reg(): 0: 0x00000005
Debug: arm7_9_common.c:944 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:976 arm7_9_debug_entry(): target entered debug state in System mode
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r0: 0x00000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r1: 0x00000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r2: 0x00000010
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0xe0000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r4: 0xe002c000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r5: 0x7ffffe3c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r6: 0x4000012c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r7: 0x00000000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r8: 0x2d7a6af5
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r9: 0x08e347c1
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r10: 0x40000180
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r11: 0x4000076c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r12: 0x40000770
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r13: 0x40000760
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r14: 0x400000f8
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x4000022c
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x4000022c
Debug: target.c:444 target_call_event_callbacks(): target event 0
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$T05#b9’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pf#d6’
Debug: arm7_9_common.c:1528 arm7_9_step(): target stepped
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pf’
Debug: gdb_server.c:680 gdb_get_register_packet():
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$2c020040#bb’
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x4000022c
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x4000022c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0xe01fc000
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x40000230
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x40000230
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$30020040#89’
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x40000230
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x40000230
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0xe01fc100
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x40000234
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x40000234
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$34020040#8d’
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x40000234
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x40000234
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r2: 0x00000001
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x40000238
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x40000238
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$38020040#91’
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x40000238
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x40000238
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x4000023c
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x4000023c
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$3c020040#bc’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$z0,40000240,4#c0’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜z0,40000240,4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$z0,40000138,4#c6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜z0,40000138,4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$z0,40000124,4#c1’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜z0,40000124,4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$z0,4000023c,4#f2’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜z0,4000023c,4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$z0,4000018c,4#f6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜z0,4000018c,4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m4000023c,4#89’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m4000023c,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x4000023c, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x4000023c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$020000eb#e9’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000180,4#5a’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000180,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000180, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000180, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$0dc0a0e1#4e’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000184,4#5e’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000184,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000184, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000184, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$00d82de9#30’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000188,4#62’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000188,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000188, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000188, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$04b04ce2#24’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m4000018c,4#8d’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m4000018c,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x4000018c, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x4000018c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$fe3ee0e3#90’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000190,4#5b’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000190,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000190, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000190, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$0b3043e2#f3’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000194,4#5f’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000194,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000194, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000194, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$0020e0e3#ef’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000198,4#63’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000198,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000198, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000198, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$002083e5#c7’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m4000019c,4#8e’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m4000019c,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x4000019c, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x4000019c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$ff3ee0e3#91’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001a0,4#83’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001a0,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001a0, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001a0, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$033043e2#c4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001a4,4#87’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001a4,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001a4, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001a4, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$0020a0e3#eb’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001a8,4#8b’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001a8,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001a8, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001a8, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001ac,4#b6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001ac,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001ac, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001ac, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$3f3de0e3#5d’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001b0,4#84’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001b0,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001b0, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001b0, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001b4,4#88’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001b4,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001b4, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001b4, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$88209fe5#0b’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001b8,4#8c’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001b8,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001b8, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001b8, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m400001bc,4#b7’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m400001bc,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x400001bc, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x400001bc, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$0e22a0e3#22’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pb#d2’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pb’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$6c070040#c4’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$qL1160000000000000000#55’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜qL1160000000000000000’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$#00’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$qC#b4’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜qC’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜$p0#a0’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p0’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$00000000#80’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p1#a1’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p1’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p2#a2’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p2’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$01000000#81’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p3#a3’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p3’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$00c11fe0#20’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p4#a4’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p4’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$00c002e0#ea’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p5#a5’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p5’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$3cfeff7f#ca’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p6#a6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p6’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$2c010040#ba’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p7#a7’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p7’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p8#a8’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p8’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$f56a7a2d#60’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p9#a9’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p9’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$c147e308#ff’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pa#d1’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pa’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$80010040#8d’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pc#d3’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pc’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$70070040#92’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pd#d4’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pd’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$60070040#91’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$pe#d5’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜pe’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$f8000040#c2’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p10#d1’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p10’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$000000000000000000000000#80’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p11#d2’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p11’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p12#d3’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p12’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p13#d4’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p13’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p14#d5’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p14’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p15#d6’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p15’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p16#d7’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p16’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p17#d8’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p17’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p18#d9’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p18’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$p19#da’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜p19’
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$df000060#f0’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜$Hc0#db’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜Hc0’
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): writing PC with value 0x4000023c
Debug: embeddedice.c:299 embeddedice_write_reg(): 16: 0x4000023c
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r14: 0x40000240
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x4000024c
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0x4000024c
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$4c020040#bd’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m4000024c,4#8a’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m4000024c,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x4000024c, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x4000024c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$40020040#8a’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$m40000240,4#57’
Debug: gdb_server.c:1237 gdb_input(): recevied packet: β€˜m40000240,4’
Debug: gdb_server.c:834 gdb_read_memory_packet(): addr: 0x40000240, len: 0x00000004
Debug: arm7_9_common.c:1676 arm7_9_read_memory(): address: 0x40000240, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:177 gdb_put_packet(): sending packet β€˜$feffffea#29’
Debug: gdb_server.c:124 gdb_get_char(): received β€˜+$Z0,40000240,4#a0’
Debug: gdb_serve
Do You have the function enableIRQ() in details?
When Your code is running in user mode it is not allowed to change the I and F bits in the CPSR.
So if You want to control them - enable/disable IRQ and FIQ - You must change to any of the privileged modes, change the bits and come back. It could be done by an SWI interrupt call, when disabling/enabling in implemented in the SWI handler.
If You don’t want to change these bits in Your code, just interrupts to be enabled then have a look at Your Startup.s or crt.s. In the startup code, where You sets up the stack pointers for different modes, You also initialize the CPSR for all these modes. For the last, user mode do not set I_BIT and F_BIT, so interrupts will be enabled by default. You can than disable/enable interrups using VIC.
focus:
VPBDIV = 1;
enableIRQ();
while(1){}
