Here is the log I get when I start openocd, attach gdb, set a breakpoint in a low priority ISR, run to that breakpoint, attempt to single step, and get whisked away into a higher priority ISR, then quit gdb and quit openocd. My clock speed is 36MHz and I get the same results whether I use a JTAG speed of 600Khz or 60KHz.
Debug: 9 0 configuration.c:88 find_file(): found openocd.cfg
Debug: 11 1 command.c:91 script_command(): script_command - interface
Debug: 12 1 command.c:108 script_command(): script_command - interface, argv[0]=ocd_interface
Debug: 13 1 command.c:108 script_command(): script_command - interface, argv[1]=ft2232
Debug: 15 1 command.c:91 script_command(): script_command - ft2232_device_desc
Debug: 16 1 command.c:108 script_command(): script_command - ft2232_device_desc, argv[0]=ocd_ft2232_device_desc
Debug: 17 1 command.c:108 script_command(): script_command - ft2232_device_desc, argv[1]=Amontec JTAGkey A
Debug: 19 1 command.c:91 script_command(): script_command - ft2232_layout
Debug: 20 1 command.c:108 script_command(): script_command - ft2232_layout, argv[0]=ocd_ft2232_layout
Debug: 21 1 command.c:108 script_command(): script_command - ft2232_layout, argv[1]=jtagkey
Debug: 23 1 command.c:91 script_command(): script_command - ft2232_vid_pid
Debug: 24 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[0]=ocd_ft2232_vid_pid
Debug: 25 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[1]=0x0403
Debug: 26 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[2]=0xcff8
Debug: 28 1 command.c:91 script_command(): script_command - jtag_nsrst_delay
Debug: 29 1 command.c:108 script_command(): script_command - jtag_nsrst_delay, argv[0]=ocd_jtag_nsrst_delay
Debug: 30 1 command.c:108 script_command(): script_command - jtag_nsrst_delay, argv[1]=100
Debug: 32 1 command.c:91 script_command(): script_command - jtag_ntrst_delay
Debug: 33 1 command.c:108 script_command(): script_command - jtag_ntrst_delay, argv[0]=ocd_jtag_ntrst_delay
Debug: 34 1 command.c:108 script_command(): script_command - jtag_ntrst_delay, argv[1]=100
Debug: 36 1 command.c:91 script_command(): script_command - reset_config
Debug: 37 1 command.c:108 script_command(): script_command - reset_config, argv[0]=ocd_reset_config
Debug: 38 1 command.c:108 script_command(): script_command - reset_config, argv[1]=trst_and_srst
Debug: 40 1 command.c:91 script_command(): script_command - jtag_device
Debug: 41 1 command.c:108 script_command(): script_command - jtag_device, argv[0]=ocd_jtag_device
Debug: 42 1 command.c:108 script_command(): script_command - jtag_device, argv[1]=4
Debug: 43 1 command.c:108 script_command(): script_command - jtag_device, argv[2]=0x1
Debug: 44 1 command.c:108 script_command(): script_command - jtag_device, argv[3]=0xf
Debug: 45 1 command.c:108 script_command(): script_command - jtag_device, argv[4]=0xe
Debug: 47 1 command.c:91 script_command(): script_command - jtag_device
Debug: 48 1 command.c:108 script_command(): script_command - jtag_device, argv[0]=ocd_jtag_device
Debug: 49 1 command.c:108 script_command(): script_command - jtag_device, argv[1]=5
Debug: 50 1 command.c:108 script_command(): script_command - jtag_device, argv[2]=0x1
Debug: 51 1 command.c:108 script_command(): script_command - jtag_device, argv[3]=0x1
Debug: 52 1 command.c:108 script_command(): script_command - jtag_device, argv[4]=0x1e
Debug: 53 1 target.c:3993 jim_target(): Target command params:
Debug: 54 1 target.c:3994 jim_target(): target cortex_m3 little 0
Debug: 55 1 target.c:4091 jim_target(): Target OLD SYNTAX - converted to new syntax
Debug: 56 1 target.c:3993 jim_target(): Target command params:
Debug: 57 1 target.c:3994 jim_target(): target create target0 cortex_m3 -endian little -chain-position 0
Debug: 59 2 command.c:91 script_command(): script_command - working_area
Debug: 60 2 command.c:108 script_command(): script_command - working_area, argv[0]=ocd_working_area
Debug: 61 2 command.c:108 script_command(): script_command - working_area, argv[1]=0
Debug: 62 2 command.c:108 script_command(): script_command - working_area, argv[2]=0x20000000
Debug: 63 2 command.c:108 script_command(): script_command - working_area, argv[3]=16384
Debug: 64 2 command.c:108 script_command(): script_command - working_area, argv[4]=nobackup
Debug: 66 2 command.c:91 script_command(): script_command - bank
Debug: 67 2 command.c:108 script_command(): script_command - bank, argv[0]=ocd_flash_bank
Debug: 68 2 command.c:108 script_command(): script_command - bank, argv[1]=stm32x
Debug: 69 2 command.c:108 script_command(): script_command - bank, argv[2]=0
Debug: 70 2 command.c:108 script_command(): script_command - bank, argv[3]=0
Debug: 71 2 command.c:108 script_command(): script_command - bank, argv[4]=0
Debug: 72 2 command.c:108 script_command(): script_command - bank, argv[5]=0
Debug: 73 2 command.c:108 script_command(): script_command - bank, argv[6]=0
Debug: 75 2 command.c:91 script_command(): script_command - jtag_speed
Debug: 76 2 command.c:108 script_command(): script_command - jtag_speed, argv[0]=ocd_jtag_speed
Debug: 77 2 command.c:108 script_command(): script_command - jtag_speed, argv[1]=100
Debug: 78 2 jtag.c:1965 handle_jtag_speed_command(): handle jtag speed
User: 79 2 command.c:372 command_print(): jtag_speed: 100
Debug: 81 2 command.c:91 script_command(): script_command - init
Debug: 82 2 command.c:108 script_command(): script_command - init, argv[0]=ocd_init
Debug: 83 3 openocd.c:143 handle_init_command(): target init complete
Debug: 84 3 ft2232.c:1382 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'jtagkey' layout (0403:cff8)
Debug: 85 131 ft2232.c:1471 ft2232_init_ftd2xx(): current latency timer: 2
Debug: 86 132 ft2232.c:1737 jtagkey_init(): 80 08 1b
Debug: 87 132 ft2232.c:1795 jtagkey_init(): 82 09 0f
Debug: 88 132 ft2232.c:256 ft2232_speed(): 86 64 00
Debug: 89 133 openocd.c:150 handle_init_command(): jtag interface init complete
Debug: 90 133 jtag.c:1625 jtag_init_inner(): Init JTAG chain
Debug: 91 133 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 92 133 jtag.c:1305 jtag_reset_callback(): -
Debug: 93 133 jtag.c:1305 jtag_reset_callback(): -
Debug: 94 133 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 95 133 jtag.c:1305 jtag_reset_callback(): -
Debug: 96 133 jtag.c:1305 jtag_reset_callback(): -
Info: 97 145 jtag.c:1414 jtag_examine_chain(): JTAG device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
Info: 98 145 jtag.c:1414 jtag_examine_chain(): JTAG device found: 0x16410041 (Manufacturer: 0x020, Part: 0x6410, Version: 0x1)
Debug: 99 145 jtag.c:327 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 100 145 jtag.c:1305 jtag_reset_callback(): -
Debug: 101 145 jtag.c:1305 jtag_reset_callback(): -
Debug: 102 147 openocd.c:156 handle_init_command(): jtag init complete
Debug: 103 147 cortex_swjdp.c:968 ahbap_debugport_init():
Debug: 104 175 cortex_swjdp.c:1012 ahbap_debugport_init(): AHB-AP ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 105 185 target.c:1200 target_read_u32(): address: 0xe000ed00, value: 0x411fc231
Debug: 106 185 cortex_m3.c:1388 cortex_m3_examine(): CORTEX-M3 processor detected
Debug: 107 185 cortex_m3.c:1389 cortex_m3_examine(): cpuid: 0x411fc231
Debug: 108 193 target.c:1200 target_read_u32(): address: 0xe000e004, value: 0x00000001
Debug: 109 201 target.c:1200 target_read_u32(): address: 0xe000e100, value: 0x00040000
Debug: 110 201 cortex_m3.c:1397 cortex_m3_examine(): interrupt enable[0] = 0x00040000
Debug: 111 209 target.c:1200 target_read_u32(): address: 0xe000e104, value: 0x00000120
Debug: 112 209 cortex_m3.c:1397 cortex_m3_examine(): interrupt enable[1] = 0x00000120
Debug: 113 217 target.c:1200 target_read_u32(): address: 0xe0002000, value: 0x00000261
Debug: 114 217 cortex_m3.c:1412 cortex_m3_examine(): FPB fpcr 0x261, numcode 6, numlit 2
Debug: 115 225 target.c:1200 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 116 225 openocd.c:159 handle_init_command(): jtag examine complete
Debug: 117 226 openocd.c:165 handle_init_command(): flash init complete
Debug: 118 226 openocd.c:169 handle_init_command(): mflash init complete
Debug: 119 226 openocd.c:173 handle_init_command(): NAND init complete
Debug: 120 226 openocd.c:177 handle_init_command(): pld init complete
Warning: 121 226 telnet_server.c:614 telnet_init(): no telnet port specified, using default port 4444
Warning: 122 226 gdb_server.c:2184 gdb_init(): no gdb port specified, using default port 3333
Debug: 123 226 gdb_server.c:2205 gdb_init(): gdb service for target cortex_m3 at port 3333
Warning: 124 226 tcl_server.c:178 tcl_init(): no tcl port specified, using default port 6666
Info: 125 25936 server.c:84 add_connection(): accepting 'telnet' connection from 0
Info: 126 31946 server.c:396 server_loop(): dropped 'telnet' connection
Info: 127 60189 server.c:84 add_connection(): accepting 'gdb' connection from 0
Debug: 128 60189 cortex_m3.c:483 cortex_m3_halt(): target->state: halted
Debug: 129 60189 cortex_m3.c:487 cortex_m3_halt(): target was already halted
Debug: 130 60197 target.c:717 target_call_event_callbacks(): target event 26 (gdb-attach)
Debug: 131 60197 target.c:3125 target_handle_event(): event: 26 gdb-attach - no action
Debug: 132 60197 target.c:3125 target_handle_event(): event: 26 gdb-attach - no action
Debug: 133 60197 gdb_server.c:2033 gdb_input_inner(): received packet: 'qSupported'
Warning: 134 60197 gdb_server.c:567 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 135 60197 gdb_server.c:2033 gdb_input_inner(): received packet: '?'
User: 136 60197 gdb_server.c:100 gdb_last_signal(): undefined debug reason 6 - target needs reset
Debug: 137 60197 gdb_server.c:2033 gdb_input_inner(): received packet: 'Hc-1'
Debug: 138 60197 gdb_server.c:2033 gdb_input_inner(): received packet: 'qC'
Debug: 139 60198 gdb_server.c:2033 gdb_input_inner(): received packet: 'qOffsets'
Debug: 140 60198 gdb_server.c:2033 gdb_input_inner(): received packet: 'Hg0'
Debug: 141 60198 gdb_server.c:2033 gdb_input_inner(): received packet: 'g'
Debug: 142 60198 gdb_server.c:2033 gdb_input_inner(): received packet: 'qXfer:memory-map:read::0,fff'
Debug: 143 60207 target.c:1200 target_read_u32(): address: 0xe0042000, value: 0x20036410
Info: 144 60207 stm32x.c:706 stm32x_probe(): device id = 0x20036410
Debug: 145 60217 target.c:1225 target_read_u16(): address: 0x1ffff7e0, value: 0x0020
Info: 146 60217 stm32x.c:751 stm32x_probe(): flash size = 32kbytes
Debug: 147 60218 gdb_server.c:2033 gdb_input_inner(): received packet: 'm0,4'
Debug: 148 60218 gdb_server.c:1173 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 149 60218 target.c:1065 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 150 67778 gdb_server.c:2033 gdb_input_inner(): received packet: 'Z1,8000f2c,2'
Debug: 151 67778 gdb_server.c:1368 gdb_breakpoint_watchpoint_packet(): -
Debug: 152 67778 target.c:1268 target_write_u32(): address: 0xe0002008, value: 0x48000f2d
Debug: 153 67787 cortex_m3.c:870 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x48000f2d
Debug: 154 67787 breakpoints.c:93 breakpoint_add(): added hardware breakpoint at 0x08000f2c of length 0x00000002
Debug: 155 67787 gdb_server.c:2033 gdb_input_inner(): received packet: 'vCont?'
Debug: 156 67787 gdb_server.c:2033 gdb_input_inner(): received packet: 'Hc0'
Debug: 157 67787 gdb_server.c:2033 gdb_input_inner(): received packet: 'c'
Debug: 158 67787 target.c:717 target_call_event_callbacks(): target event 9 (gdb-start)
Debug: 159 67787 target.c:3125 target_handle_event(): event: 9 gdb-start - no action
Debug: 160 67787 target.c:3125 target_handle_event(): event: 9 gdb-start - no action
Debug: 161 67787 gdb_server.c:1332 gdb_step_continue_packet(): -
Debug: 162 67787 gdb_server.c:1346 gdb_step_continue_packet(): continue
Debug: 163 67787 target.c:3125 target_handle_event(): event: 3 old-pre_resume - no action
Debug: 164 67787 armv7m.c:134 armv7m_restore_context():
Debug: 165 67797 target.c:717 target_call_event_callbacks(): target event 6 (resumed)
Debug: 166 67797 target.c:3125 target_handle_event(): event: 6 resumed - no action
Debug: 167 67797 target.c:3125 target_handle_event(): event: 6 resumed - no action
Debug: 168 67797 cortex_m3.c:636 cortex_m3_resume(): target resumed at 0x1
Debug: 169 67817 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 170 67839 cortex_m3.c:132 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 171 67871 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x15
Debug: 172 67893 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x20000604
Debug: 173 67915 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x150000
Debug: 174 67937 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x119dad
Debug: 175 67959 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x20000086
Debug: 176 67981 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 177 68005 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 178 68027 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x2000059c
Debug: 179 68049 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x20000054
Debug: 180 68071 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0x20000290
Debug: 181 68093 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0xf2981eba
Debug: 182 68115 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0xd23f63ed
Debug: 183 68137 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 184 68159 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20001798
Debug: 185 68181 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x0
Debug: 186 68203 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8000f2c
Debug: 187 68225 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000038
Debug: 188 68247 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20001798
Debug: 189 68269 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0x5a96f7d8
Debug: 190 68291 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 192 68313 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 193 68335 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 194 68357 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 195 68367 cortex_m3.c:321 cortex_m3_examine_exception_reason(): External Interrupt(40) SHCSR 0x20000, SR 0x0, CFSR 0xffffffff, AR 0xffffffff
Debug: 196 68367 cortex_m3.c:398 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8000f2c, target->state: halted
Debug: 197 68367 target.c:717 target_call_event_callbacks(): target event 4 (early-halted)
Debug: 198 68367 target.c:3125 target_handle_event(): event: 4 early-halted - no action
Debug: 199 68367 target.c:3125 target_handle_event(): event: 4 early-halted - no action
Debug: 200 68368 target.c:717 target_call_event_callbacks(): target event 5 (halted)
Debug: 201 68368 target.c:3125 target_handle_event(): event: 5 halted - no action
Debug: 202 68368 target.c:3125 target_handle_event(): event: 5 halted - no action
Debug: 203 68368 target.c:717 target_call_event_callbacks(): target event 10 (gdb-end)
Debug: 204 68368 target.c:3125 target_handle_event(): event: 10 gdb-end - no action
Debug: 205 68368 target.c:3125 target_handle_event(): event: 10 gdb-end - no action
Debug: 206 68368 gdb_server.c:2033 gdb_input_inner(): received packet: 'g'
Debug: 207 68368 gdb_server.c:2033 gdb_input_inner(): received packet: 'z1,8000f2c,2'
Debug: 208 68368 gdb_server.c:1368 gdb_breakpoint_watchpoint_packet(): -
Debug: 209 68368 target.c:1268 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 210 68378 gdb_server.c:2033 gdb_input_inner(): received packet: 'm8000f2c,4'
Debug: 211 68378 gdb_server.c:1173 gdb_read_memory_packet(): addr: 0x08000f2c, len: 0x00000004
Debug: 212 68378 target.c:1065 target_read_buffer(): reading buffer of 4 byte at 0x08000f2c
Debug: 213 69195 gdb_server.c:2033 gdb_input_inner(): received packet: 'Hc0'
Debug: 214 69195 gdb_server.c:2033 gdb_input_inner(): received packet: 's'
Debug: 215 69195 target.c:717 target_call_event_callbacks(): target event 9 (gdb-start)
Debug: 216 69195 target.c:3125 target_handle_event(): event: 9 gdb-start - no action
Debug: 217 69195 target.c:3125 target_handle_event(): event: 9 gdb-start - no action
Debug: 218 69195 gdb_server.c:1332 gdb_step_continue_packet(): -
Debug: 219 69195 gdb_server.c:1352 gdb_step_continue_packet(): step
Debug: 220 69195 armv7m.c:134 armv7m_restore_context():
Debug: 221 69195 target.c:717 target_call_event_callbacks(): target event 6 (resumed)
Debug: 222 69195 target.c:3125 target_handle_event(): event: 6 resumed - no action
Debug: 223 69195 target.c:3125 target_handle_event(): event: 6 resumed - no action
Debug: 224 69210 cortex_m3.c:688 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 225 69210 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 226 69232 cortex_m3.c:132 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 227 69264 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x15
Debug: 228 69286 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x20000604
Debug: 229 69309 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x150000
Debug: 230 69331 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x119dad
Debug: 231 69353 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x20000086
Debug: 232 69375 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 233 69397 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 234 69419 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x2000059c
Debug: 235 69441 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x20000054
Debug: 236 69463 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0x20000290
Debug: 237 69485 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0xf2981eba
Debug: 238 69507 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0xd23f63ed
Debug: 239 69529 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 240 69551 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20001778
Debug: 241 69573 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff1
Debug: 242 69595 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x800029c
Debug: 243 69617 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000022
Debug: 244 69641 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20001778
Debug: 245 69663 cortex_m3.c:1180 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0x5a96f7d8
Debug: 246 69685 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 248 69707 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 249 69729 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 250 69751 cortex_m3.c:1206 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 251 69761 cortex_m3.c:321 cortex_m3_examine_exception_reason(): External Interrupt(18) SHCSR 0x20000, SR 0x0, CFSR 0xffffffff, AR 0xffffffff
Debug: 252 69761 cortex_m3.c:398 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x800029c, target->state: halted
Debug: 253 69761 target.c:717 target_call_event_callbacks(): target event 4 (early-halted)
Debug: 254 69761 target.c:3125 target_handle_event(): event: 4 early-halted - no action
Debug: 255 69761 target.c:3125 target_handle_event(): event: 4 early-halted - no action
Debug: 256 69761 target.c:717 target_call_event_callbacks(): target event 5 (halted)
Debug: 257 69761 target.c:3125 target_handle_event(): event: 5 halted - no action
Debug: 258 69761 target.c:3125 target_handle_event(): event: 5 halted - no action
Debug: 259 69761 target.c:717 target_call_event_callbacks(): target event 10 (gdb-end)
Debug: 260 69761 target.c:3125 target_handle_event(): event: 10 gdb-end - no action
Debug: 261 69761 target.c:3125 target_handle_event(): event: 10 gdb-end - no action
Debug: 262 69761 cortex_m3.c:693 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 263 69761 gdb_server.c:2033 gdb_input_inner(): received packet: 'g'
Debug: 264 69765 gdb_server.c:2033 gdb_input_inner(): received packet: 'm800029c,4'
Debug: 265 69765 gdb_server.c:1173 gdb_read_memory_packet(): addr: 0x0800029c, len: 0x00000004
Debug: 266 69765 target.c:1065 target_read_buffer(): reading buffer of 4 byte at 0x0800029c
Debug: 267 69775 gdb_server.c:2033 gdb_input_inner(): received packet: 'mfffffff0,4'
Debug: 268 69775 gdb_server.c:1173 gdb_read_memory_packet(): addr: 0xfffffff0, len: 0x00000004
Debug: 269 69775 target.c:1065 target_read_buffer(): reading buffer of 4 byte at 0xfffffff0
Debug: 270 69783 cortex_swjdp.c:228 swjdp_transaction_endcheck(): swjdp: CTRL/STAT error 0xf0000021
Error: 271 69783 cortex_swjdp.c:242 swjdp_transaction_endcheck(): SWJ-DP STICKY ERROR
Debug: 272 69787 cortex_swjdp.c:250 swjdp_transaction_endcheck(): swjdp: status 0xf0000001
Error: 273 69825 cortex_swjdp.c:257 swjdp_transaction_endcheck(): dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x0, nvic_bfar 0xe000edf8
Debug: 274 69835 cortex_swjdp.c:228 swjdp_transaction_endcheck(): swjdp: CTRL/STAT error 0xf0000021
Error: 275 69835 cortex_swjdp.c:242 swjdp_transaction_endcheck(): SWJ-DP STICKY ERROR
Debug: 276 69839 cortex_swjdp.c:250 swjdp_transaction_endcheck(): swjdp: status 0xf0000001
Error: 277 69877 cortex_swjdp.c:257 swjdp_transaction_endcheck(): dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x0, nvic_bfar 0xe000edf8
Warning: 278 69877 cortex_swjdp.c:725 ahbap_read_buf_u32(): Block read error address 0xfffffff0, count 0x1
Debug: 279 69877 gdb_server.c:2033 gdb_input_inner(): received packet: 'md23f63ed,4'
Debug: 280 69877 gdb_server.c:1173 gdb_read_memory_packet(): addr: 0xd23f63ed, len: 0x00000004
Debug: 281 69877 target.c:1065 target_read_buffer(): reading buffer of 4 byte at 0xd23f63ed
Debug: 282 69887 cortex_swjdp.c:228 swjdp_transaction_endcheck(): swjdp: CTRL/STAT error 0xf0000021
Error: 283 69887 cortex_swjdp.c:242 swjdp_transaction_endcheck(): SWJ-DP STICKY ERROR
Debug: 284 69891 cortex_swjdp.c:250 swjdp_transaction_endcheck(): swjdp: status 0xf0000001
Error: 285 69929 cortex_swjdp.c:257 swjdp_transaction_endcheck(): dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x0, nvic_bfar 0xe000edf8
Debug: 286 69939 cortex_swjdp.c:228 swjdp_transaction_endcheck(): swjdp: CTRL/STAT error 0xf0000021
Error: 287 69939 cortex_swjdp.c:242 swjdp_transaction_endcheck(): SWJ-DP STICKY ERROR
Debug: 288 69943 cortex_swjdp.c:250 swjdp_transaction_endcheck(): swjdp: status 0xf0000001
Error: 289 69981 cortex_swjdp.c:257 swjdp_transaction_endcheck(): dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x0, nvic_bfar 0xe000edf8
Debug: 290 69991 cortex_swjdp.c:228 swjdp_transaction_endcheck(): swjdp: CTRL/STAT error 0xf0000021
Error: 291 69991 cortex_swjdp.c:242 swjdp_transaction_endcheck(): SWJ-DP STICKY ERROR
Debug: 292 69995 cortex_swjdp.c:250 swjdp_transaction_endcheck(): swjdp: status 0xf0000001
Error: 293 70033 cortex_swjdp.c:257 swjdp_transaction_endcheck(): dcb_dhcsr 0x30003, nvic_shcsr 0x20000, nvic_cfsr 0x0, nvic_bfar 0xe000edf8
Debug: 294 74994 gdb_server.c:2033 gdb_input_inner(): received packet: 'k'
Debug: 295 74995 target.c:717 target_call_event_callbacks(): target event 10 (gdb-end)
Debug: 296 74995 target.c:3125 target_handle_event(): event: 10 gdb-end - no action
Debug: 297 74995 target.c:717 target_call_event_callbacks(): target event 27 (gdb-detach)
Debug: 298 74995 target.c:3125 target_handle_event(): event: 27 gdb-detach - no action
Info: 299 74995 server.c:396 server_loop(): dropped 'gdb' connection
