Hi, recently i buy the ev board in my country to make some experiments, te hyperterminal works fine already sent a SMS and make a call, now i want to send a text to the board and based on the content of the text make an output enabled on I/O ports board, anybody can help me with this need some hints to start to work on it
the only way you can accomplish this (without using a separate micro controller) is to use the built in python scripting. You can create a script that looks for the messages and responds accordingly. The Telit has alarms that you can create so at fixed intervals it will check for messages and then do what you wanted based on the content.
