Generating a custom BSP for Apollo3 Blue
I need to generate a BSP for a custom PCB using the Apollo3 Blue. I understand I need to use the BSP generation script to do this. Is there a tutorial/example of the steps that need to be taken?
Thanks, Sid
If you go to AmbiqSuiteSDK/boards_sfe/common/bsp_config/ there’s a readme file with instructions about how to create the .src file that’s used as an input to the pinconfig.py script to generate a .c and .h
