I’ve also noticed a decrease in reported accuracy with the Torch in comparison with the Facet.
Reported accuracy with the Facet has typically been ~14mm with RTK Fix for both horizontal and vertical.
The best I’ve been able to achieve with the Torch is 17mm horizontal accuracy and 29mm vertical. Although most of the time vertical is more like 60-70mm.
RTK corrections are provided by a CORS network. Rovers are approx. 9 km from nearest base.
Shooting a known benchmark, both the Facet and the Torch were within ~7mm ft of the horizontal position.
Vertically, the Facet was off 25mm and the Torch was off a whopping 75mm.
Torch ARP is set to 115 for L1 and 118 for L2.
Current UM980 config:
$command,config,response: OK*54
$CONFIG,ANTENNA,CONFIG ANTENNA POWERON*7A
$CONFIG,NMEAVERSION,CONFIG NMEAVERSION V410*47
$CONFIG,RTK,CONFIG RTK TIMEOUT 120*6C
$CONFIG,RTK,CONFIG RTK RELIABILITY 4 4*74
$CONFIG,BESTPARA,CONFIG BESTPARA 16.00 10.00*02
$CONFIG,PPP,CONFIG PPP TIMEOUT 300*6C
$CONFIG,DGPS,CONFIG DGPS TIMEOUT 0*6F
$CONFIG,RTCMB1CB2A,CONFIG RTCMB1CB2A DISABLE*70
$CONFIG,ANTENNADELTAHEN,CONFIG ANTENNADELTAHEN 0.0000 0.0000 0.0000*3A
$CONFIG,PPS,CONFIG PPS ENABLE GPS POSITIVE 200000 1000 0 0*69
$CONFIG,SIGNALGROUP,CONFIG SIGNALGROUP 2*16
$CONFIG,JAMMING,CONFIG JAMMING AUTO*2B
$CONFIG,AGNSS,CONFIG AGNSS DISABLE*70
$CONFIG,COM1,CONFIG COM1 115200*23
$CONFIG,COM2,CONFIG COM2 115200*23
$CONFIG,COM3,CONFIG COM3 115200*23
Changing the RTK RELIABILITY and SIGNALGROUP parameters didn’t appear to affect results significantly.
Next step is to set up a local base (within ~1 km).
Is the reported accuracy supposed to take into account the distance from the base?
With RTK Fix, the Facet almost always reports ~14mm regardless of distance to base. Doesn’t matter if its 10 km or 60 km away.
I wonder if Ubox and Unicore are calculating these accuracy numbers differently.
Could the helical antenna be negatively affecting performance in comparison with the Facet?
