Hello All,
I recently put together a quad band GM862 GSM+GPS module with usb interface. The problem is that I am unable to communicate with the device at all ![]()
I installed the usb driver mentioned on the website; a COM port also shows up in the device manager’s hardware profile.
I reset the board and the green light blinks a couple of times before going silent.
I tried using the hyperterminal with the flow control set to Hardware and None, neither of them works.
When I type anything in the hyperterminal, nothing appears in the window i.e., neither the thing I type nor any respone from the device.
I tried looking in the forum for similar problems but I am afraid I haven’t found anything that I could use.
Most people have been able to acheive basic communication atleast.
I look forward to everything that you may have to suggest and get this problem solved.
Thanks in advance,
Shashank.
