GM862 does not work with Hyperterminal.
hello
buy GM862 Evaluation Kit Board
But when connecting it to the “Hyperterminal” does not work.
Try entering the command “AT” to show me an “OK” but does not work.
Check all options, baud rates, etc.
The green LED flashes Module gm862 me constantly.
and the red LED is lit properly.
How could you leave the factory settings?
Greetings
Are you on the correct baud rate and settings in the terminal? How are you powering the board?
Baud rate: 96000
and I have it connected to a battery charger 9 volt.
worked perfectly before, but it stopped working one day and never worked.
Could it be that there is internally unconfigured?
It is very strange, because I have a Skypatrol GPS, and works perfectly with the same configuration.
What can it be?
It should work fine under those settings, have you checked with Telit?
