Hi,i start using GM862-GPS for the asset tracking project,now it seems i meet a problem on CHARGE pin.
Actually,we don’t have the backup battery solution,so i connect this pin to Ground.In about one month testing, the GM862-GPS seems irregular “freeze”:GSM can’t be communicated for several times.After ON/OFF the module,the issue disappear.
Besides the power supply stability,does the CHARGE pin connection have any tricksy impact on the GM862-GPS function and performance?coz i don’t have the charging circuit schematic of GM862-GPS on hand,it’s hard to analyze this problem.
Any help is appreciated a lot.look forward to your reply.
Leon :shock:
