Preferably PDIP format so that I can experiment on the breadboard. Thanks
unebonnevie:
Probably a bit more info would make it more likely you’d get a reply.
Do you want to output sound, use use sound as an input? where you you tried looking so far?
I would to produce arcade kinds of sounds. Thx
You can make simple arcade sounds like those on your AVR with a simple DAC or even 8 bit, R-2R Network… ![]()
