I cannot however find the 1Hz signal that is reported to be present on PIN 6 of the device. I’ve probed every pin with no pull, pull up, and pull down resistors to no avail.
The LED blinks at .5 Hz when the GPS signal is locked.
Yes, I viewed each pin with an o-scope from seeed, but I was looking for a 1Hz square wave so could have missed the short pulse. Thanks for pointing me to that discussion. I’m a “clock nut” too! Have you heard of ClockTHREE?
