Dear Support:
I bought the antenna(ublox ANN-MB-00-00), whose port is male (with pin). The port of gps board(ZED-F9P-01B-01) is still male(with pin).
I wonder how I can could connect them together. Thanks.
Michael
Dear Support:
Michael
Hi Michael.
If you bough [SparkFun’s ZED-F9P it should have a connector that mates with your antenna. If you have someone else’s ZED-F9P and it has a center pin on it’s connector you’re going to need an adapter that has the appropriate connectors.
Where did you get the GPS and can you send photos showing the connector?](https://www.sparkfun.com/products/16481)
I have the exact same issue. my board came with a PR-SMA connector, not a SMA connector! The spec sheet says SMA, and the UBLOX antenna also expects a SMA (even the name of the board has SMA in it!). I believe that some parts may have gotten mixed up during the assembly of this board.
A photo of my board with the wrong connector on it is attached.
If you purchased the board directly off our website, just [fill in the form on this page with your order number and the URL to this forum post and we can replace it for you.
If you purchased from a distributor or Amazon you will need to let them know you have a defective product and arrange with them for an exchange.](Return Policy - SparkFun Electronics)
My distributer is out of this board.
If anyone else ends up in this situation, I believe the correct connector that you can solder on yourself is:
https://www.sparkfun.com/products/593
or you can use this adapter:
I hope that helps.
