Hey, I’m having issues with the performance of my f9p base and rover pair, fixing and holding are from what I can tell performing somewhat poorly and many cycle slips, etc. seem to occur. I know the f9p has a built-in RTK solution but that’s another issue I’m having for another time. I noticed in the data of my base station that it seemed to give somewhat erratic and weird-looking output:
as opposed to when I download a dataset online and it looks more smooth and evenly distributed:
I also checked with multiple other previous data instances of me using that receiver as a base and the pattern seems to be reoccurring and the elongated-ness seems to appear in most plots and even point in the same direction coordinate-wise.
Am I seeing the source of my issues here? or is this an expected behavior? if not what could be the causing problem? for context, I am using an U.fl. adapter to a good antenna and sadly it unlatches if not handled carefully sometimes. this has happened at most maybe a dozen times.
I appreciate the help! Thanks
