GPS MiniMod
I have a GPS Minimod and can see the GSA, RMC and GSV messages that it transmits. The trouble is that the message data is not valid (a V code shows up in the third column of the RMC message for status = not valid).
I can’t find in the documentation anywhere what the expected messages are supposed to be when there is no fix (I’m indoors currently).
I actually wasn’t expecting any messages, but I do get what look like real messages except the data isn’t valid.
This is probably correct, but I want to compare it to the documentation. There is no discussion of what to expect when there is no fix.
Has anyone seen this?
Yes, this is what you should expect to see if you have no fix.
