zelda
1
Hello ,
i connected GPS copernicus “SparkFun GPS Module - Copernicus II DIP (12 Channel)” with
antenna “Antenna GPS Embedded SMA” and FTDI 3.3v to my computer but i receive all the time this
lines of GPS messages with COOLTERM software.(+ see picture), I tried outside the house too. What is the problem?
$GPGGA,0,00,*66
$GPVTG,N*30
$GPGGA,0,00,*66
$GPVTG,N*30
$GPGGA,0,00,*66
$GPVTG,N*30
links:
https://learn.sparkfun.com/tutorials/te … -mac-linux
https://learn.sparkfun.com/tutorials/co … 1448806086
NEED HELPS!!! THANKS
Take the setup outside, to where you have a clear view of the sky and be prepared to wait up to 15 minutes for a “cold start” fix.
gm
3
You might want to try [Trimble Studio as it will query the module and let you know if the module detects the antenna being open or shorted.](http://trl.trimble.com/dscgi/ds.py/Get/File-484972/TrimbleStudio.exe)
zelda
4
Thank you but i don’t need Trimble Studio.
Jremington was right. NOW IT WORKS PERFECTLY!
I just needed to put GPS module outside and wait few minutes for the first time.
Thanks a lot for your help
